What are all these wires . . . too messy!
Discussion in 'Technical' started by mashori, Sep 23, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Hey guys, is there a way I can find out what each of those wires does coming out of that square thing in the firewall? It's looking so cluttered and I'm tired of looking at it.
  2. Dave B
    The square thing is where the wires for the front of your car attach to the wiring harness for the car. The purple wire with the yellow stripe, is the resistive wire that feeds the coil from the factory.
  3. justin has a 74
    kentucky
    you could always weld a piece of metal their so you cant see it :rofl:
  4. Bryant
    paint it all flat black. it all disapears that way.
  5. blugene
    Close the hood and stop looking at them :p.
    You need them so don't get too crazy with them. Might flat black them like Bryant said.
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    so what you car gurus are tellin me . . . if I have a problem under the hood I should approach it the following way:
    1) Identify problem (i.e. messy wires)
    2) Cover up problem by painting with flat black
    3) Resolve problem completely by closing hood
    OK, got it! :rofl2:Now I know what to do with that pesky gas leak I've been having onto the hot manifold. :clap:
  7. rthomas771
    First thing I'll would do is take that blue splice connector off and splice that wire the correct way with srink wrap. Get a wiring diagram and it will tell you what and where each color wire goes. Wrap electrical tape around the wires to bundle them together.
  8. Bryant
    stick a rag under the gas leak, paint it black, close hood. oh and i didnt tell you to do that if you do it.
  9. blugene
    If you want to clean it up, there are several ways to do it. You can partialy take the harness out (or all of it) and clean it and re-wrap it. To clean it you can use hand cleaner and shop rags and nylon brushes. Rinse thourly and blow dry them before wraping them with a quality tape. You could even use wire loom to further protect the wires. Try avoiding the urge to use yellows and reds etc. unless it goes with your under hood theme or componants. Red may look good anyway since you may have the flames theme soon anyway :biglaugh:
  10. Bryant
    mo needs blue loom. with his blue stripes and blue interior.:boxing:
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Mo is staying away from looms . . . I'm afraid of "anti-sissi-ism"
  12. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    That ain't no mess of stinkin' wires...THIS is a mess of wires:
  13. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    That looks like a spool failure at a bait and tackle shop!
  14. Bryant
    that looks like it needs yellow loom :rofl2:
  15. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Wonder how much weight Mark has added to his car in wiring and accessories? :thumbs2:
