Water pump problems
Discussion in 'Technical' started by chase259, Jun 25, 2014.
  1. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    So my water pump gasket have out on me, I was trying to replace it and I broke off 2 bolts, a piece of the timing cover and the water pump still won't come off, so now I need to replace both...ugh this car, now my question is are the timing cover and water pump on a 74 ford maverick 302 the same as the 87 mustang? Because all the parts look identical I have the drivers side outlet, the passenger side ac outlet and a passenger side outlet that goes to the thermostat this car is one headache after the other, and the water pump is original so everything is stuck. I'm in desperate need of help here
  2. Bryant
    they are different. the 87 mustang pump is reverse rotation and the cover is for reverse rotation and doesnt have a dip stick hole in it.
  3. 71gold
    breaking bolts removing an original water pump is common...the ones that go through the water jacket rust almost halfway through...:yup:
    note...coat the new bolts with... http://www.rustbullet.com/ ...before installing them.
  4. chase259
    chase259 Member
    Calgary, AB, CAN
    1970 ford maverick
    So where can I get the timing chain cover?
  5. mojo
    Do U mean Rustbullet paint? I use anti-seeze compound on mine.
  6. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Melvin's Classic Ford Parts has them
  7. 71gold
    I put anti seize on the threads and the rustbullet on the bolt.
  8. floridaboy
    floridaboy Member
    Central Florida
    1972 comet (with maverick front end)
    Im pretty sure the parts stores (autozone, advance...) can get them but make sure you get the one to match your water pump/belt system and not the car
  9. simple man
    simple man Member
    Bunnell,Florida
    Just curious, what piece of the cover is broken off? Could you post a pic of it. I had a piece break out of the side where one of the long bolts goes through. It didn't allow coolant or oil to escape, so we reused it. The bolt had rusted inside of the cover and when it turned the outside of the cover split and a ½" section broke off. :huh:
  10. baddad457
    Just FYI: I use ordinary everyday Teflon thread paste on those bolts to stop the seepage from the threads. Antiseize on the bolt shanks of any bolt that passes through and aluminum part. I have heard that the timing covers are the same, I think they're different in the layout of these two covers, set em side by side and verify this before buying a timing cover.
  11. blugene
