Vacuum needle fluctuates( crazy )
Discussion in 'Technical' started by Danielle, Nov 12, 2009.
  1. Danielle
    Danielle Member
    Maine
    2 door Red with white top
    Ok I was having a problem with a unsteady idle so I rebuilt my Carburetor ,( which had a bunch of crap in it ) BUT still have a problem. So I connected a Vacuum Gauge and the needle is really crazy at idle around 11in to 15in SHAKEN LIKE CRAZY if you rev it up the needle still shakes but the vacuum goes to 15in and 20 in .
    Vacuum leak at the Manifold??? or Valve train issue's . Overall the motor runs preety smooth you can hear a slight miss at idle but it sounds pretty good and smooth revved up ,
    Open to any and all thoughts on this????
    Danielle
  2. rthomas771
  3. Mavman72
    Sounds like a burnt valve or a lousey tune...Have you thrown a tune up at it yet???
    Plugs/wires/cap/rotor/fuel filter/points&condensor (if it has em).Set timing and adjust carburetor.Could be a simple vacuum leak too.
  4. Earl Branham
    Lugoff, SC
    Danielle; check the vacuum modulator line. Make sure it is there, and that the rubber line is good, and the steel line isn't kinked, bent or rusted apart.
  5. Danielle
    Danielle Member
    Maine
    Thanks everyone
    Tomorrow i will get at it again , had to quit when the sun went down tonight . The link Thomas posted was great. The bad news is I may be looking at a burned valve .
  6. Danielle
    Danielle Member
    Maine
    Earl
    I have two lines that go to the tranny vacuum modulator one is hooked to the intake and the other is not hooked to any thing ,Any ideas where it should get hooked two .
    1974 250cubicin straight 6 with a c-4 .
  7. Earl Branham
    Lugoff, SC
    Danielle; check on the modulator and see if there are two ports. If not, plug off the one that is not hooked up. That will at least get the vacuum leak. On a '74, I think they all had one port. Let us know how it works out. Good luck!
  8. Danielle
    Danielle Member
    Maine
    Ok
    Sorry I am still bugging every one, But I have not yet figuried this one out .
    I still have a problem !!
    So here is what I have done ,Compression check 150,145,140,140,145,150
    reset timing 8 degrees btc ,rebuilt carb, replaced plugs ,points, condensor, cap, rotor, plugwires, removed EGR and installed steel plate with gasket,
    Sympton's rough idle , runs good above idle .
    if I spray carb cleaner near front of the cyl head between intake runnels and valve cover. The idle speeds up ???
    If you put a vacuum gauge on it reads 15 to 20in but it vibrates like crazy between the two readings like crazy,
    So are the intake manifold and head all one piece?? Is there a gasket between the two ?
    and do these 250 6cyl have a history of cracked Intakes?
    Any and all thoughts are welcome .
  9. Mavman72
    Sounds like a cracked intake runner or the soft plug at the end of it(round metal plug in end of intake)has a hole in it or is no longer sealing well. Make sure there arent any un plugged/un covered vacuum nipples in the vicinity where you sprayed.
  10. Danielle
    Danielle Member
    Maine
    WO HOO!!! PROBLEM SOLVED
    Yes I thought that the intake might have a crack in one of the runners too, so I steam cleaned it and was giving the manifold a very close inspection today, But it all looked very good, so I went to remove the EGR spacer that is between the manifold and Carb and there was my problem staring me in the face , the gasket between the manifold and spacer had a big piece missing out of it , about a one inch section was gone.
    Man am I glad thats over with, I was getting worried I might have to get a whole new cyl head ,
    Thanks for all the help guys, it really helps to know you are all here to bounce ideas off of and get a new perspective on things when you hit a mental block on these type of problems ,
    On the road again, Yee haw! ~ Danielle
  11. Mavman72
    Glad you found it!!! Have fun!!!
