Vacuum and EGR
Discussion in 'Technical' started by mywifeisawesome, Oct 1, 2016.
  1. mywifeisawesome
    mywifeisawesome Member
    Pittsburgh, Pa
    1973 Mercury Comet
    Hi everyone. I was wondering if on my 73 Merc Comet with a 250 six if I could eliminate the egr valve and block it off? If so anyone make a block off plate or do I need different manifold? Also can I eliminate anything else under the hood that has vacuum lines running too it? Thank alot guys.
  2. rthomas771
    I blocked my off. The EGR is now an carb spacer/adapter
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    Also keep in mind that the tuneup will change slightly without it too.
