vac line on top of the carburetor help
Discussion in 'General Maverick/Comet' started by classic ccg, May 28, 2015.
  1. classic ccg
    ringgold GA
    72 maverick
    Heyguys I'm almost done with the maverick but i was wanting to see if you know what this vac line is on top of the carburetor i have one line going down to the fuel pump so now i just need to know about this one
  2. CaptainComet
    I think that is a vent for the fuel bowl, and the line connects to the little filter in the air cleaner base. (it's been a while ... I might be wrong. Somebody verify this please)
    Please put some clamps on the fuel line! You might end up with a Car-B-Q otherwise.
    Krazy Comet likes this.
  3. Krazy Comet
    That's a later emissions carb, def not '72... I believe it routed to the charcoal canister, but it's stupid and will work just as well vented into base of air cleaner... The '72 carb was open to atmosphere just a hole in top of carb with no connection...
    I second the clamps, with a hot engine bay the hose will soften and blow off...
  4. classic ccg
    ringgold GA
    72 maverick
    ThNk you guys we just connected it to fire it up one time but I definitely will put a clamp on there I don't think I would like to have a barbecue of my car the used taste kind of rusty
  5. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    You should put one on the other end too
  6. rthomas771
    Replace the fuel line and filter also
