v8 wont fire now
Discussion in 'Technical' started by BrianB, Jan 11, 2011.
  1. BrianB
    BrianB Member
    1973 Maverick
    ok i just installed the pertronix ignitor 1 in my stock 302, and now the car wont start, it just doesnt get fiire to the plugs, sometimes it will hit like 1 or 2 times but then nothing. also i just replaced the spark plugs and gaped them to 35, what could it be?
  2. maverick75
    Re-check your wiring, sounds like you missed something.
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Gap too big? Double check the gap between the sensor and the reluctor ring. Your plate on the distributor could be loose and the sensor could be farther away then it was when you set it the first time.
  4. BrianB
    BrianB Member
    1973 Maverick
    ok, also do i need the ballast resistor? and what does it do? and whoa someone else from riverside
  5. maverick75
    Did you buy the kit used or was it new? If it was new follow the instructions. Ive never installed those kits as im fond of the duraspark system. Where are you in riverside? Im in the eastside right next to lincoln high school..
  6. 71gold
    the instructions show you how to check to see if the ignitor is good...i got one that was bad out of the box...come to find out someone bought the system and somehow blew it and then returned it...it took me a minute to trace it down...:hmmm:
    ...:Handshake...
  7. BrianB
    BrianB Member
    1973 Maverick
    i got it new and watched a video on how to install it, i live around the tyler mall, i think i actually saw you driving your mavrick a while back, me and my girlfriend thought it was cool to see another mav on the road! haha
  8. john T
    john T Member
    coalinga CA
    72 maverick grabber
    check you ignition wire thats what i forgot when switching from points to the accel
  9. maverick75
    It wasnt me :D my mav is parked until the new engine is finished. There are tons on my side of the city though. Like i have a list of 15 with their addresses :)
  10. BrianB
    BrianB Member
    1973 Maverick
    Oh crap, i forgot to put the ground wire back on! and ooh wow ive only seen like 2 or 3 on the road since i got mine a year ago.
  11. BrianB
    BrianB Member
    1973 Maverick
    ok now the ground wire is in and now theres absalutly nothing except right when i stop turning the key the last split second it sounds like it starts to fire..
  12. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    this may sound dumb but take the pertronix out and put your points back in and make sure it will still start with the points. If it does then reinstall the pertronix. It sounds like you either got a bad pertronix or you have a wire going to the wrong place.
    By the description in the post I quoted it sounds like something is hooked up in the wrong place and they are not getting voltage at the correct time.
    But do yourself a favor and try putting the points back in and like I said if it works with the point then start from scratch and follow the directions carefully and reinstall the pertronix.
  13. Bryant
    it sounds like your not geting the correct voltage to the pertronix during cranking. put a volt meter on the positive wire and see what it is when your cranking the motor.
  14. BrianB
    BrianB Member
    1973 Maverick
    the whole reason i bought the ignition is because the points were bad.. it seems like a waste of money to go buy new points.
  15. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    make sure you are getting 9-12 volts to the red wire with the key on and the same while the engine is cranking. You might try puting a jumper between the positive battery cable and the ignition lug on the solenoid.
