V8 Motor mounts - Which way do they go?
Discussion in 'Technical' started by 357WinMag, Jun 4, 2010.
  1. 357WinMag
    357WinMag Member
    Folsom, Ca
    72 base model, 351 swap in progress
    Hello all,
    I have just finished up preping the engine bay for the 351W. Got the frame stands in place and a new set of motor mounts. Since the mounts are indentical, my question is; do they mount on the motor with the longer tabs bolted towards the front or the back?
    Thanks,
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    do you have any pic's
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    They are marked L and R, or at least mine were....
  4. 357WinMag
    357WinMag Member
    Folsom, Ca
    There are no markings other than the part number which is the same on each one. My understanding is that they are the same, just that they can go on the block either long tab forward on each side or short tab forward. :huh:
  5. 302-72-mav
    302-72-mav Member
    sactown CA
    hey did you make it to the all ford car show at sac-racway it was the 16'th sieragrabber was there and a drag race maverick
  6. 357WinMag
    357WinMag Member
    Folsom, Ca
    Hello Guys,
    Thanks for your input, especially Jacks'. As usual I was over thinking the obvious. The motor mounts can only go on the way they go on. Drivers side short tab to the front, passengers side long tab to the front (DUH!).
    I did not make it to the all ford show last month. I completely forgot about it. My brother-in-law succumbed to cancer and his muzzle loader buddies had a verry cool send-off for him that weekend. They had a black powder cannon, stuffed his ashes in it and shot him off a mountain!
    Here's a couple of pic's
  7. blugene
    Sorry to hear about your brother n law. That's intresting about the cannon.
  8. mojo
    Nice car! It looks like u paid close attention to underhood detailing. I like it.
  9. 1973Maverick357
    Cookeville TN
    Nice shock tower shave nice and clean!!
  10. FordCountry180
    FordCountry180 Member
    Parkesburg, PA
    1970 Maverick -302 - -C4 Trans -8" rear
    I agree, looks top notch. Dude, your avatar pic is disturbing!
  11. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    i have one motor mount that says 2257 and another that says 2268 will they work on my 302 ford maverick
  12. PaulS
    They should be identical side to side.......
    They will only bolt to the block one way and still give you access to the bolts.
  13. runeking40
    runeking40 Member
    Illinois
    1973 maverick
  14. PaulS
    Check the distance from the engine mounting pads on the mount to the frame mounting hole on the mount. If they are the same for both mounts then use them.
