Upper control arm- grease fittings
Discussion in 'General Maverick/Comet' started by Chlorin8ed, Feb 23, 2018.
  1. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    1972 Mercury Comet, 1980 Chevy Malibu, 1987 Chevy R10
    I just bought MOOG RK621369 upper control arms. They come with "straight" in grease fittings. I installed some 90* grease fittings. When I put the arm into place they hit the side of the shock tower and the bolts do not go in all the way. Side note the bolts are 1/4' shorter than my originals. I have seen people put the 90* fittings on, so how did you do it?
  2. Krazy Comet
    stumanchu and 71gold like this.
  3. stumanchu
    stumanchu Stuart
    Portland, OR
    I put 90* in the front and straight in the back, as my control arms got moved 1" down and slightly to the rear. This made room for a front 90 and had to make a nickel sized hole in shock tower for the rear zerk. Had I known about those Scott Drake zerks, I might have been able to use one of those in the rear.....they look fairly close fitting. Eehhhh learn something new every day.
  4. 71gold
    you were lucky not to have a hole cut to start with. around here most we see looks like the same person cut the holes. they are about the size of the end of a pop can. Jeff has a pic of the ones on his car. I found the pic. all this hole for a nickle size job...:slap:
    I welded a big washer over mine and found a rubber plug to pop into the center.
    stumanchu and Ronald Hopkins like this.
  5. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    #@$%%@ UGGGGGG!!! :slap: Missed that little detail.. Thanks Krazy C
