Upgraded Seat belts?
Discussion in 'Parts Interchange' started by orl2swh, Sep 13, 2010.
  1. orl2swh
    orl2swh Member
    Orlando Fl
    1973 Maverick Grabber
    My 73 grabber has the stock shoulder harness. I am getting this car ready for my son to drive next year to school. I would like to put a front seat belt system that does not give an option to use the shoulder harness. Looks straight forward to do. Wondering if any body has all ready found a good fit?
  2. maverick75
    So just the lapbelt? Its really not a good idea, if your ever rear ended your head will end up on your steering wheel. There are deaths that happen that way. A lot of guys dont like the shoulder harness because its uncomfortable and unadjustable. But the good news is that theres aftermarket kits that give alot more comfort. Also i wouldnt use junkyard seatbelts its just seems like safety hazard. And new ones are not even that expensive.
  3. orl2swh
    orl2swh Member
    Orlando Fl
    Poor wording on my part
    Just the opposite. I don't want him to have a choice. Shoulder belt and lap belt one piece
  4. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    These: Lap Belt With Shoulder Harness
    -With 8" Door Post Extension Bracket
    from Andover Restraints. Pick the length and style of buckle end, based on bucket or bench seats. I cut one side the plastic housing on the bucket seat ends so they would not be so tight against the tunnel - they are really more designed to bolt to the seat like on a late model vehicle. My only complaint really is the intertia locks are super sensitive, so you have to pull them out pretty slowly or they lock.
  5. maverick75
    Thats great! I got mine from here: http://www.morrisclassicconcepts.com I havent had a chance to try them out though.
  6. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
  7. car-nut
    car-nut Glenn
    conn.
    Juliano's in Ellington, Conn. Has just about any configuration of seat belts you could want.
    http://www.julianos.com/
  8. Earl Branham
    Lugoff, SC
    I used the Andovers, and they fit and work great!
  9. Grabber5.0
    Kansas City, MO
    71 Grabber
    I looked at their site a lot when I was building my parts list -- in fact, their tech articles are great -- but they don't show a shoulder belt with a drop to get the pivot point lower.
  10. Grabber5.0
    Kansas City, MO
    71 Grabber
    Never seen a 70, but even if the factory anchor points are not there, they sell anchor plates you can weld into pretty much anything.
  11. canuck222
    canuck222 vroom, vroom... Supporting Member
    Woodstock, ON
    '73 Mercury Comet, 302, Auto
    Can anyone clarify exactly what I need to purchase. I have '73 with a bench seat.
    So from your post above and what the site states, all I need is...
    1) Lap Belt With Shoulder Harness
    18" long (because it's a bench seat)
    and that is it? no extra brackets or anchors required?
  12. Grabber5.0
    Kansas City, MO
    71 Grabber
    Since you have a bench seat, you should not need anything else. Even with my buckets, I didn't like the way the anchors they show in the tech articles held the belt, so I bolted them directly to the trans tunnel and cut the plastic housing to let it bend toward the seat easier. You might measure your existing buckle ends to make sure 18" isn't too long -- really though you have to make sure the end you get is long enough to reach up through the seat when it is as far forward as you will need it.
