unknown part
Discussion in 'Technical' started by Gert Sanders, Oct 18, 2005.
  1. Gert Sanders
    Gert Sanders El Torro Caminando
    Belgium
    1974 Mexican Built Maverick
    Not sure where this question should go, so here it is. Does anyone know the function of the round part (in the middle of the picture) ?
    It sits on the passenger side and is connected via a small tube coming from ??? and with a larger tube going to the aircleaner on the carb.
    Do I need it? It does not seem to do much. Can anyone tell me what this part does, and if it is essential to have.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    It's the charcoal canister for the gas tank vent.. supposed to be connected to your gas tank vent and your air cleaner.
  3. Gert Sanders
    Belgium
    hi Dan, should it be replaced from time to time, or is this filter mounted and good for life?
  4. dmhines
    Cumming, GA
    Just use as is ... never heard of somebody replacing it ... I doubt they are still made and NOS ones cost a couple hundred bucks ...
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I think that is an emission part that is intended to capture raw gas fumes and direct them to the engine... Dmhines covered the rest.
    I have always removed them and free vented the tank.
    I should have kept them for the resto crowd I guess.
  6. Gert Sanders
    Belgium
    thanks guys, I will just clean up this part and put it back when I assemble the car again. Now I also know where the gas tank vent is.
  7. Jamie Miles
    Alto, GA
    I've had a few
    Mines been unhooked since long before I got my car. I just haven't gotten around to takeing it out yet.
  8. Mavaholic
    Only problem with that is your venting the fumes under the hood.
  9. ratio411
    ratio411 Member
    Pensacola
    Well when ya put it like that, it sounds like a problem...:16suspect
  10. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    I use to have a '72 Chevelle (forgive the "C" word).....It's emission can had a filter on the bottom and I would change it at every other tune-up.....
  11. merlin19705
    merlin19705 74 comet
    tucumcary nm
    74 mercury comit 302 2dr auto
    i just took mine out i did not see no need for it.:D
  12. Mavaholic
    They dont rob any power and vent gas fumes back into the carb. You really should use it or plug up the line and switch to a vented cap. The cardboard hose is still available from Ford so I would recomend hooking it up and let it do its job. Part # for the hose is D4ZZ9D667A for a 40" piece.
