Turn signals not working
Discussion in 'Technical' started by soooulpower, May 10, 2008.
  1. soooulpower
    Mapleton Depot, Pennsylvania
    I replaced all the bulbs in my car but my stupid turn signals still won't blink. Is it a relay? Is there any way I can test?
  2. Mavman72
    When you turn the signal on do you hear a dink dink dink noise??? If not it is probably your turn signal flasher relay.It is located behind the dash (up high) to the left of the steering column(from drivers point of view)Looks like a little round can with 3 prongs on it for the plug.
  3. soooulpower
    That's got to Be it. I don't hear anything and the arrows on the dash just stay on.
  4. Mavaholic
    There are 2 flashers under the dash. One for the turn signals and the other for the emergency flashers. Make sure you get the right one.
  5. soooulpower
    Thanks for the tip! That's a good thing to know before I get the part.:Handshake
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Yeah,, the obvious first thing would be to replace the flasher. Let us know if that fixes it.
    Dan
  7. soooulpower
    :biglaugh:Good one!! I think I have an extra bottle in the trunk, I'll check...:rofl2:
  8. soooulpower
    Later today I'm going to the parts store to pick up an innertube for my other car, so I'm ordering 2 headlights and the blinker relay I need. I also have to get my work car out of the shop. My exhaust fell off. Again.
  9. younger
    younger Member
    Longview Tx
    77 comet 78 c-10 4wd
    I am having a similar problem but I occasionally can hear the relay cycle once then nothing, does anyone have an exact location for this as I have 37 year old ac ducting to work around.
  10. 71gold
    :Welcome:...:Handshake
  11. younger
    younger Member
    Longview Tx
    Thank you and mine happened to be the relay... but I noticed my cluster plastic is disintegrating so more fun.
  12. mighty76
    mighty76 Member
    calgary,alberta canada
    76 maverick,58 ford f250, 79 f150 stepside 4x4
    Look under the drivers side dash, you may have to search a bit for two round,usually silver flashers, if you find both, turn your hazards on, and replace the one that does not click, if none of them make any noise, replace em both :Welcome:
  13. younger
    younger Member
    Longview Tx
    I had already verified the bottom with the hazards, interesting note the oem blue plastic relay was still hooked up behind my cluster, and the fact that it was plastic and mounted to the metal of the dash threw me off... but in the interest of not damaging the factory ac ducts I went in through the front and replaced the other relay. In the interest of not hijacking this thread after reading the rules I'll be posting my own thread about my car. done.
