Turn Signal lights
Discussion in 'Technical' started by BrassMav, Apr 26, 2011.
  1. BrassMav
    BrassMav New Member
    Portland, Oregon
    '72 Maverick
    I went to change out one of my front turn signal lights. Seemed normal. before buying some new bulbs, I pulled a bulb from the tail lights to test the connector up front. As soon as I removed that bulb, None of the sockets now work with either the headlights or parking lights on. Is one of the fuses devoted to those lights? The headlights still work, and to my knowledge I had thought they shared a fuse.
    Input?
  2. simple man
    simple man Member
    Bunnell,Florida
    Yes there is a fuse for your parking and tail lights. If you removed a bulb while the lights were on,it can short out and blow a fuse!:)
