Tranny issues.
Discussion in 'Technical' started by PAINTANK, Aug 16, 2007.
  1. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Takes a second or two to go into gear.
    I start my mighty Comet, shift to reverse and it takes a second or two to actually go. The same goes for foreward gear. This happens only at first when I fire up the car. After a drive it stops doing it.
    Um...wtf yall?
  2. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    My car does that going into first... try a vacume modulator, check all vacume lines going to the tranny. Also let it warm up abit (couple minutes). check fluid level... hope that helps.
  3. PAINTANK
    1973 Comet 2 dr
    Vacuum lines?
    I had planned on eliminating all those hoses under my hood soon.
    Argh!
  4. grbmaverickmo
    Aquashicola, PA
    Mine did it to. I adjusted the band and it took care of it.
  5. David74maverick
    Arizona
    If you have a auto you need that vacuum line unless you install a manuel valve body kit... even then I don't know.
  6. Phyphor1
    Phyphor1 Member
    1972 Mercury Comet
    First off:
    Change your fluid and filter, check the bottom of the pan for a lot of debris... if it all looks good, you might want to get a 300 pound test guage and the hose to connect to the left side of the trans, near the shifter (it's just a bolt there, easy to find)
    Check the pressures coming out, see what it says,
  7. PAINTANK
    1973 Comet 2 dr
    I ran the car for a few minutes and checked the fluid and it was looooow so I added a half quart of fluid and it drives like a different car now. Smooth shifts, no lag and it even sounds better. The hump gets less hot too.
  8. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    Low fluid will do it every time....LOL
