tranny fluid dump??????
Discussion in 'Technical' started by JCJD, Jan 6, 2004.
  1. JCJD
    JCJD Member
    Now that the 71 Grabber is up and running. (Was up and running)
    I am driving down the freeway when I notice clouds of white smoke rolling out the back.
    Tranny fluid is pouring out. And I do mean POURING.
    There is so much fulid under there I can't tell where it is coming from, but it apears to be the front of the tranny between the tranny and torque converter.
    Have I a blown seal? torque converter?
    Something had been getting louder in the drive train lately.
    It still moves if you add fluid so it seems the transmission is ok???
    Thanks for any help.
    JD
  2. Earl Branham
    Lugoff, SC
    JCJD; Sounds like a bad front pump. Ask 71gold about that particular animal. Time for a new tranny! Condolences,
    Earl
  3. 71gold
    :rolleyes: :rolleyes: thanks earl, i wasn't going to say anything. but comming back from the meet in savannah i lost 9 qts. of fluid. m.a.v. chris and i checked it out today and we think it is the front seal. the trans. mount is bad so we think it might have something to do with it. my tranny man is going to pull it later this week and let me know what he fines. i will post the findings when i get them...frank...:( :(
  4. Kelly Evans
    Kelly Evans Member
    Centerville GA
    1969 1/2 Maverick
    tranny
    Frank will the trans off the 250 at my house interchange with yours.(didn't know if they were same trans/bell housing etc). Let me know if you need me to bring it if so.
  5. JCJD
    JCJD Member
    If it's a front seal, is that something I can replace or am I better off buying a rebuilt tranny?
  6. 71gold
    jcjd, the seal is something you can replace. you might want to replace the front and rear bushings. the tranny will have to be pulled to put the seal in. in my case i am going to let a pro. do it because the tranny has just had a new front and rear seal installed. i need to know why it went. mine was also making a noise. i will let you know what we find. you, also let us know if you find anything....frank...:bananaman :bananaman
    p.s. kelly, thanks, but i think this tranny is fine. we are looking at the flexplate or converter.
  7. JCJD
    JCJD Member
    She goes into the tranny shop Friday.
    I am shocked and appaled by the price but like the man said they havent built a C4 in over twenty years so it's not like parts are abundent.
    I'll let you know how it goes.
    Jeff
  8. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Price ???
    Sounds a little heavy for a front pump seal , what shop and how much if you don't mind me asking ?
    Richard
  9. JCJD
    JCJD Member
    I got a complete rebuild done for a grand.
    Picked the car up today and its running great.
  10. don graham
    wow, i recently had ac-4 rebuilt for $350. that was dropping it off at his shop.:)
  11. JCJD
    JCJD Member
    I could have got it done much cheaper as well. But this shop would not do bench work as he wanted to check and clean the cooler and make sure the pressure through the cooler was right so the tranny would last. He machines the clutch plates to the proper thickness ( some stock ones are too thick) and gives a year warrenty.
    I have no problem with paying more for quality work, so all in all I am happy with job.
    Jeff
