I was having trouble getting traction with some Nitto 555 drag radials but Thursday.I had 14 pounds into the rear tires when I come off the line the front wheels went in air about a foot.I know some of you may have experience this but this was my first time and it was a little scary.I'll get used to it.Now I know I take the front shocks off and it will hook.I work 3rd shift so its not many times I get to go to test n tune this about every 3 weeks .Our test and tune is going to be on Sunday afternoon instead of thrusday.Have a great day.
we had a Guy on here at one time that had that problem every time he left from a light on the street. I don't remember what he did to correct it.
I had Nitto 555s 315s on my Mach I and I felt they were not up to the task. Now I have Kumho 335s and the car spins them silly as well...
I had Nitto 555's 295's on my Cobra Mustang and I liked my first set quite a bit. The second set...not so much.
In cold weather Nittos will give far worse traction on the street than street tires... First time I went out in cold weather and stepped down on it, they broke loose so quick I thought the trans was slipping... They only hook when warm to hot...
You can when things start to break. Like the driveshaft, transmission, axles or the rear differential
