Torque values for '76 brake caliper bolts, bracket to steering knuckle?
Discussion in 'General Maverick/Comet' started by bmcdaniel, Aug 7, 2021.
  1. bmcdaniel
    Thanks in advance.
  2. dyent
    dyent Member
    vancouver bc
    This is from Ford Shop Manual:
    Anchor Plate to Spindle - Upper 90-120 ft/lbs. this must be tightened first
    - Lower 55-75 ft/lbs.
    Caliper Key Retaining Screw (socket head) - 12-16 ft/lbs.
    David
  3. bmcdaniel
    :thumbs2:
  4. Powerband
    Powerband Member
    NY's \H/
    ... interesting severe torque differences and top to bottom tightening sequence , trying to figger' why? ...
    [​IMG] .[​IMG]
    have fun
  5. dyent
    dyent Member
    vancouver bc
    Top bolt is a larger fastener, uses 3/4" socket and lower uses 5/8" socket.......personally, I would just take torque value in the middle, 105 ft/lbs. for upper and 65 ft/lbs. for the lower, use anti-seize on threads.......
    David
  6. Acornridgeman
    Wisconsin
    The way I was taught back in the 70's, was when you see a split torque spec, it refers to wet and dry torque. If the bolt is lubed or "wet" - it reduces the torque needed by 25%.
  7. bmcdaniel
    This ^^^
