Toploader shifter problem
Discussion in 'Transmissions' started by jean282, Aug 30, 2011.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    I am trying to convert my car to manual and the shifter dont seem to be in the right place it almost hit the steering when I go to the reverse.
    The number i found on the transmission is :
    case : RF - D2AR-7006-0
    Tail shaft : DOZR-7A040-A
    I would like to know if the shifter is at the right place close to the back of the transmission.
    the number i found on my shifter is 3216274 - 3306126.
    thank you
  2. mercgt73
    When I did my toploader, Reverse was down-left, not up-left. :huh:
  3. tody
    tody Member
    cologne, germany
    shifter is in the right place.
    i would think that it's a problem of the shifter handle - looks like it's bent?
  4. Joe Dirt
    Maybe its just the curve of the stick, mine wasn't close with a straight stick
  5. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    My shifter its it 14" high. Also 2 of my rod need modification i think it because it from a torino. If i bought an install kit for mustang do i need to modify the rod or it a bolt on ? Can i remove the stick from this shifter ? Also do you have a part number for the stick ?
  6. tody
    tody Member
    cologne, germany
    i have a complete 4spd toploader with a hurst competition plus from a mustang in my comet. fit without issues.
    your shift handle looks like a hurst, too. iirc, the chrome stick can be taken off. try to slide some small metal plates left and right of the shifter to release it.
  7. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    Do you know from which year your setup came from ?
  8. bmcdaniel
    Your stick looks like some of the factory ones that you couldn't unbolt. I would cut 3/4 of the way through it near the bottm, bend it to where you want it, then weld back together.
  9. baddad457
    That's where it is with the factory shifters. Hurst's have it reversed to prevent shifting from 1st into reverse in the "heat of battle"
  10. baddad457
    It's bent the wrong direction and you can't unbolt it and swap levers. Either do what BMC said or get a different Hurst Shifter that's straight up and bent rearwards. Oh, and a Torino shifter install kit won't have the correct shifter rods for your Mustang tailhousing. Toploaders had several different tailhousings(with different shifter locations) in two lengths (for cars) Yours is a Mustang tail with a small block shifter location.
  11. jmgford
    jmgford Member
    Iowa
    That appaears to be an factory Ford Hurst shifter. I would advise not cutting it up if it is. They would bring enough money used to buy a new aftermarket Hurst shifter that you need. I believe the round shaft with the Hurst flats on each side was only used by Ford. The knob looks like a '72 Torino unit and I have seen the knob alone bring $75 or more on Ebay.
  12. baddad457
    Looks too "new" to me for it to be an original O.E. Ford/Hurst shifter. Maybe a repop ? Could be wrong though.
  13. jmgford
    jmgford Member
    Iowa
    Maybe. I wasn't aware they were reproducing those types. :huh:
  14. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    I just finished the modify the rod. It was more easy that i though. I had only the gring at one place the 1-2 rod and modify the bend on the 3-4.
    I had the same idea to cut and weld the shifter but i had no idea that the shifter worth something. The shifter look in good shame because i cleaned it before installing it. You can see it when i bought the kit. I removed the all the part on a 73 torino gran sport.
    http://mmb.maverick.to/showthread.php?t=19796
    Now i need to find if the shifter are worth selling it or i should cut and weld the stick.
  15. PaulS
    You can change the direction of reverse by installing the reverse lever at the transmission 180 degrees - instead of left and up it will be left and down - that may solve your problem without modifying the stick.
