timing cover leak on a 200 - 6
Discussion in 'Technical' started by Wantamav, May 7, 2008.
  1. Wantamav
    Wantamav Located in Macomb Mi.
    Michigan
    '71 2 door
    It appears that I've got a leak between the front timing cover and the oil pan on my 200. Do you change these gaskets out in pairs or can they be done separately. Can both of them be changed with the motor in the car? Advice is appreciated as always.
    Thanks!
  2. PaulS
    What kind of leak do you have between the front cover and the pan - Oil is free to drain into the pan between the two.
  3. Wantamav
    Michigan
    '71 2 door
    I guess that the oil appears to be at the front cover to oil pan joint. Maybe it's actually coming from the cover to block gasket. Are there any tricks to gasketing these sixes in the car?
    Thanks,
    Todd
