Time to run Air around the Garage
Discussion in 'Other Automotive Tech & Talk' started by RobertBailey, Sep 21, 2009.
  1. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    All of these look to be the same manufacture
    http://www.rapidairproducts.com/rapidair.asp
    http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200367525_200367525
    http://www.sears.com/shc/s/s_10153_...pressors?keyword=rapidair&sLevel=0&sLevel=0|2
    This one looks to be the same but in a generic box
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66747
    Anyone had any experience with this stuff. I looks to be 1/2 inch OD which would be about 1/4 ID. Rapid air makes an all aluminum runner and also a hybrid aluminum/nylon hose that comes in bigger sizes for more pressure and CFM.
    Any thoughts.
    Robert
  2. don graham
    Robert, I've looked at them before but never compared each one. As soon as I get my compressor hooked up I'm going to try it myself. The rapid air one shows 1 compressor manifold and 1 compressed air outlet. The HF one shows 1 compressor manifold and 2 compressed air outlets. :)
  3. Jamie Miles
    Alto, GA
    I've had a few
    The metal fabrication shop I work part time at has just regular old PVC pipe for the air lines.
  4. rthomas771
    It is against OSHA regulations to use compressed air in PVC pipe because it will explode like a bomb without warning. PVC can be used if it is properly encased in steel, cement, or some other approved material.
    http://www.osha.gov/dts/hib/hib_data/hib19880520.html
  5. 71gold
    that's wild...i have seen PVC used in 100's of shops/garages...
    the plant i worked at had a...clear plastic tubing...like that blue stuff...after about 3 years it was busting every day somewhere.
    i was just thinking the other day about installing PVC air lines in my shop...
    i wonder if CPVC would be better, it;s for...hot water.
    ...:yup:...
  6. RobertBailey
    I have 3/4 PVC in the upper garage and yes....if something falls and hits the hose fitting it shoots around the garage...found out one day:oops::D
    from what I can see all of these I listed are the same. now a days in new construction they use PEX tubing to run water. I helped a friend about 10 years ago use PEX in his place and it is still there doing the job.
    My only concern is will this stuff give enough air flow(CFM). using one tool at a time shouldn't be an issue since that is about the size of the air hose laying on the floor:p.
    Robert
  7. rthomas771
    According to the link I posted only one type of plastic pipe has been approved for use with compressed air is Acrylonitrile-Butadiene-Styrene (ABS), its marked on the pipe as approved for compressed air supply. Compressed liquids do not stored energy like compressed air.
    I too see PVC in a lot of shops...but never in the industrial world
  8. Rando76
    Rando76 Member
    Claremore, OK
    I was wondering about CPVC as well. Maybe it wouldn't be as good as ABS, but would it be better than PVC. :hmmm:
  9. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    CPVC would be better than PVC. PVC is mostly used for drain applications not pressure. Not sure how either would hold up to constant pressure. I never thought about using these but may give it a try.
  10. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I've seen PVC used in a few places, and wouldn't recommend it.
    It's also against OSHA as stated before, but who's going to check your personal house/shop?
  11. 302-72-mav
    302-72-mav Member
    sactown CA
    they used some plastic tubes on the show TRUCKS! when they did the small garage buildup
  12. rthomas771
    I'm not a scientist nor do I hold a PhD...I'm just a country boy down in Georgia. But I do know CPVC is still a plastic pipe. I am using Type L 1/2" copper pipe on my system. Using metal piping will help in controlling moisture in the lines
  13. Jamie Miles
    Alto, GA
    I've had a few
    With three full time employees, and one part time (me), OSHA doesn't come around much. :biglaugh: But the pipe has been in there since the late 90's, and they've never had a single problem out of it. I could see why it wouldn't be a good idea in a large scale factory that OSHA would be conerned with (all the air lines are steel at Kubota), but on a small scale it works just fine. I wouldn't think twice about using it in my garage.
  14. j miller
    Polson, Mt
    if you are going to put plastic pipe for compressed air cpvc is no better than pvc. as a plumber we regularly tested plastic lines with 120 lbs pressure and it held for the test length. the problem with plastic is it gets brittle in the heat and cold therefore causing blowouts. if i were to use any plastic pipe i would use schedule 80 pvc or plastic fire sprinkler pipe. these are 2x thicker and rated for pressures above 120lbs.
    it is FAR safer to use a metal pipe or one specifically formulated to run air. don't scrimp on safety. i've seen injuries caused by plastic pipes exploding at 120lbs due to pipe or fitting failures.
