Tie Rod Ends
Discussion in 'Technical' started by aubman82, Sep 22, 2008.
  1. aubman82
    aubman82 Member
    South Carolina
    1974 Maverick
    I'm trying to replace the tie rod ends and I got as far as removing the cotter pin and castle nut. I can't seem to get the tie rod end off. What do I do now? I have a 1974 Mav 2 door with I6-200ci.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I am guessing you are trying to remove it from the spindle knuckle.
    Loosen the nut almost all the way ( leave it on by almost the depth of the nut. Use a large hammer (I use a 3 lb mini sledge) and strike the knuckle on the side. Do not hit the tie rod end or nut. The shock from the hammer blow to the knuckle will release the taper from the spindle. You can do the same with the ball joints.
  3. Bob Wiken
    Fayetteville, Arkansas
    I use a pickle fork ( free to borrow ) from Autozone. But you'll still need the hammer.
    I've found that hammers are an intergral part of front end work.
  4. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    If you use the method Allan described, you will not damage the tie rod end. Sometimes it takes a few hard whacks, but it will come apart. I have not used a pickle fork since I learned about this method!
  5. Bryant
    ya dont bother with the pickel fork. it will only mess up the dust boots.
  6. aubman82
    aubman82 Member
    South Carolina
    1974 Maverick
    Ok, I went out and borrowed a tie rod end puller. I took the old tie rod ends off and counted the turns to get it off. When I put them back on and drove the car, it sounds like the tires are skidding. I'm wondering if I have knocked the allignment way way off?
  7. Grabber5.0
    Kansas City, MO
    71 Grabber
    If it had been aligned with worn-out tie rod ends, the toe is probably off now. I'd take it for an alignment if you don't like buying tires. It's a good idea after replacing front-end parts anyway, especially tie rod ends.
  8. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Yeah, you can eat tires in a matter of a couple hundred miles if the toe is badly out. Just ask my boy! He had that issue when he first got his car.
  9. maverick1970
    Missouri
    I just did a disc brake upgrade on mine and it appears the later tie rod ends are shorter than the early ones. Like you I counted the turns but the tires squeal bad. I will have mine aligned after I swap the rear springs and shocks out.
