the diffrence between 3.00 and 3.25 rear gear ratio
Discussion in 'General Maverick/Comet' started by 302-72-mav, Nov 12, 2009.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    i just broke my 8'' rear end at the track a 3.00-1 and i found one that is a stock 3.25-1 ratio i have a t-5 trans and was wondering how much would this make a diffrence
    with the stock 3.00 ratio and 245/50/r17 rear tires my first gear was 25 then second was 40 to 45
    why i an asking this is because i don't want to go there and break this rear end because the gear is not high enough :huh::huh:
  2. PaulS
    The difference in the final drive road speed will be 8% lower at the same RPM. You are not likely to notice any difference in acceleration.
  3. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I can't help you with your question but would you be willing to post some ETs? I'll have similar engine mods with a 3.00 rear. Would expect my ETs to be somewhere close to yours when its done. Thanks.
  4. Bryant
    with a t5 trans, i would recomend 3.80s. that will give you good off the line perfomance and you can still cruse comforatably on the freeway.
  5. 302-72-mav
    302-72-mav Member
    sactown CA
    i want 3.73 gears or something around that 3.80 sounds good to
    the first time i went to the race track (yesterday) that's when i broke my rear end the car did not make it 2 feet :cry: :rofl2:
    i was mostly mad because i did not even get to run it
    but my guess would be in the 15's
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Bryant helped me pick the best ratio for my rear end, he also built it for me actually. I have a C4 so probably not too helpful for you. I noticed a huge difference going from stock on my 8".
  7. Joe Dirt
    3.80 is what i put in mine havent got to go to the track but it is alot spukier now
  8. scooper77515
    I love my 3.80. But I drove Rick Book's car (soon to be Yellow75's car) a couple nights ago to get it loaded on the trailer. It has a 4.11 or 4.56 or something along those lines. I tell you, it feels like an extra 50 hp when you tap the gas.
  9. 302-72-mav
    302-72-mav Member
    sactown CA
    yup the pic's
    there is a crack in the thing that holds the smaller gear
  10. Bryant
    if you broke one 8" youll brake another. time to up grade. we are just starting to modify ford exploer 8.8s to be pinion centered and narrowed down to about 57"s. this is a really good way to go. i would recomend either going to the 8.8 or a 9". puting more money in the 8" will be wasted next time you blow it up. its that stage 3 clutch that broke it.
  11. scooper77515
    I hope I break mine.
    Just the excuse to get that 9" out of the attic and build it up.
  12. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    If you need an excuse sooner than that, let me know and I'll make sure something terrible happens to your 8", like maybe the entire center section falls out while everybody's asleep and rolls away out of sight... :16suspect
  13. gulupo
    gulupo Member
    nuevo laredo,Monterrey mexico, Laredo Tx
    1970 ford maverick
    i have a 8.8 1989 mustang GT rearend with 5 lug axles from a ranger, with the 3.00 gears i guess. going to install 4.10. the problem is the weak T-5, thats why i haven“t installed slicks.
  14. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    I beg to differ. If he is guesstimating that his ET's are going to be around 15 seconds in the 1/4 mile then there is no way that he should have problems with a good 8 inch rear.
    There are a LOT of guys on here that are running plenty of HP and have a nice 8 inch rear with posi-traction and beat the hell out of them and they don't break.
    i am going to guess that whatever broke in his rear was probably weak to begin with.
    With that T-5 you are going to need at least a 3.55:1 to make that car launch.
    I have a basic stock 302, mild cam, 4 bbl carb and duals with a 4 speed manual and a lock right locker and the stock 2.7?:1 rear gears are a dog. I am planning on going with 3.55 gears as soon as I have the $$$ lined up and get the time to pull my center chunk.
    I am running 1,900 - 2000 RPMs at 55 in 4th gear with the 2.7?:1 gears Figuring on 2,300 @ 55 and somewhere around 2,500 @ 60-65 when I upgrade the gears.
  15. Bryant
    ive seen plenty of diffs brake that were not behind a high powered motor. you rev the motor up to 4 to 5 grand and drop the clutch, the shock load is huge. something will brake. hes at a point where he has to spend some money, he should spend it on a up grade that wont brake, like a 8.8 or a 9"
