thanks
Discussion in 'Technical' started by OMEGA1, Apr 15, 2007.
  1. OMEGA1
    OMEGA1 Member
    GOODYEAR, ARIZONA
    1972 GRABBER
    Thanks to all that gave me advice on how to get my maverick to pass emissions. It passed! I set the timing to 0, had the screws out 1/4 turn and 4 bottles of alcohol later, it passed way below standards.
    Once again thanks for the advice, I couldn't of done it without your help!
  2. stmanser
    Davenport, Iowa
    no prob..
    good to hear another hard working american had to "slip" through the cracks to get their american muscle car to pass emissions...
    ahh.. gotta love it
  3. don graham
    congratulations, next advice would have been to move here to pinal county. no testing. :)
  4. stmanser
    Davenport, Iowa
    pinal is cool.. pima is evil
  5. Rando76
    Rando76 Member
    Claremore, OK
    I didn't know that there was any state that had emissions requirements for vehicles before 1980 - or in this case, before 1974. :huh:
  6. stmanser
    Davenport, Iowa
    yup... arizona has ALL cars go through emissions.. i dont see why, the air isnt that bad..
    i wonder if california, in all its analness, requires older cars to emission test..
    anyone want to elaborate?
  7. maverick75
    only if the car is 76 and up:bouncy:
  8. Rocco
    Rocco Member
    Chicago, IL
    1977 Maverick
    February 1st, Illinois changed to no longer test vehicles 1995 and older. :)
  9. DonCARLSON
    DonCARLSON Member
    St.Augustine Fl.
    1970 maverick,1974 Maverick
    I lived in Colorodo springs several years ago they also have i sniff test as well as visual. my 1970 camaro at the time had to pass.
  10. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Not all, just '67 and up, cause they were the first to have emmisions standards. But you only have to pass the standard that was set for the vehicle when it was made. As for why, its pretty simple. Rust. We don't get it here, so there are a LOT of old cars on the road, and the EPA won't allow the state to not test older cars because they make up a signifigant portion of the driving "fleet". The law we just got for "classic" automobiles was what happened to the legislatures try to exempt all cars 25 years or older, after the epa got finished with it. But you just learn how to make it pass, and trust me, you can get anything to pass.
  11. Rocco
    Rocco Member
    Chicago, IL
    1977 Maverick
    The Ill. gov'nr did some dancing around the "signifigant portion of the driving fleet" issue. Basically he only wanted to test (and have equiptment for testing) the OBD II cars, which are 1996 & up. Sort of a cost cutting thing.
  12. Rando76
    Rando76 Member
    Claremore, OK
    Wow.
    In Oklahoma, we have no emissions tests for any vehicle. We have no inspections either. Emissions laws do apply, but they are a visual test (make sure the cats are there).
  13. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    did you fail the first time if so what was the readings before and after you timing, air/fuel, alcohol changes? I've failed emissions three times my hydrocarbons are in the 700 to 800 range for some reason. any info would be great. thanks.
  14. Maverick Man
    California
    depends what you call old.
    1976 and up cars all need to be smoged checked in cali! only other way around it is reg as a historical vech at 25 years or older.
  15. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Omega1, where in Goodyear are you? I am also in Goodyear around the Thomas and Litchfield Road area. :)
