Thanks for the input - Here's what I bought
Discussion in 'Technical' started by mattmanb, Aug 29, 2006.
  1. mattmanb
    mattmanb Member
    Richmond, VA
    1977 2dr 302
    O.K. Guys and Gals this is my buy list from Summit: So much for leaving the Mav cherry...
    Cam - Edelbrock Performer-Plus Cam and Lifter Kits
    Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 270/ 280, Lift .448/ .472, Ford, Small Block, Kit
    Rear Sway Bar - Addco Performance Anti-Sway Bar Kits
    Sway Bar, Rear, 3/ 4 in. Diameter, Steel, Gold, Ford/ Mercury, Kit (you guys said I already had a front Sway Bar)
    Carb- Holley Street Avenger Carburetors
    Carburetor, Street Avenger, 570 cfm, Square Bore, 4-Barrel, Vacuum, Electric Choke, Dichromate
    Intake Man - Weiand Stealth Intake Manifolds
    Intake Manifold, Stealth, Dual Plane, Aluminum, Natural, Square Bore, Ford, 221-302
    Rear Diff - Powertrax No-Slip Traction Systems
    Differential, No-Slip Traction System, 28-Spline, Ford, 8 in
    Headers - Hooker Super Competition Headers
    Headers, Super Competition, Full-Length, Steel, Painted, Ford/ Mercury, Maverick/ Comet, 289-302
    Fan - Proform Electric Fans
    Electric Fan, Single, 15 in. Diameter, Puller, 2,800 cfm, Black, Plastic, Ford, Mustang, Kit
    Various guages , filters and gaskets... I'm on the lookout for a used 351 head. What did I miss and, is the cam ok?
    Thanks, Matt :dance:
  2. Mavaholic
    Woo Hoo!!!!! Nuttin like seeing that brown truck pullin up just knowin its full of goodies!!!
  3. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Looks like wise puchases to me.(y)
  4. MikeG747
    MikeG747 Member
    Arkansas
    Matt keep us posted on installing all of these goodies!(y)
  5. maverick75
    Those street avengers are awesome my friend just put on on his 350.
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I'd go with something else like a COMP cam.
    Your front sway-bar may no longer be large enough if you put the 3/4" rear sway-bar on there. You should upsize the front.
    Everything else sounds good...
  7. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    What was the total?
  8. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    sounds good to me should be alot of fun! keep us posted:drive:
  9. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Sounds like it's going to be a blast once you get it back together.
    Now, about those headers, are they the 1-3/4" primary headers? Do you have the Part Number handy?
    Good luck - and enjoy!
  10. T.L.
    T.L. Banned
    Southern Colorado
    You should run 1-5/8" primarys with stock heads on a 302. Larger primaries are best suited for aftermarket heads...:cool:
  11. mattmanb
    mattmanb Member
    Richmond, VA
    1977 2dr 302
    Header info
    HOK-6110HKR
    Brand:Hooker Headers Product Line:Hooker Super Competition Headers Header Material: Steel Header Finish: Painted Header Style: Full-length Primary Tube Diameter (in): 1 5/8 in. Collector Diameter (in): 3.000 in. Tuned: Yes Primary Tube Length (in): 30 in. Primary Tube Gauge: 18-gauge Collector Attachment: 3-bolt flange Flange Style: Standard Flange Thickness (in): 5/16 in.
  12. mattmanb
    mattmanb Member
    Richmond, VA
    1977 2dr 302
    Total $
    $2135.63
  13. T.L.
    T.L. Banned
    Southern Colorado
    Dang, that's how much I need for my paint job!...
  14. Mavaholic
    I think the only difference between the Hooker Comps and Hooker Super Comps is the tubes are about 6" longer on the Super Comps.
  15. don graham
    i believe the hooker super comp headers are a little lighter also. thinner material for racing. at least that's what i was told.:)
