tail pipes
Discussion in 'Technical' started by billrogers, Mar 7, 2013.
  1. billrogers
    billrogers Member
    hudson falls ny
    70 maverick
    i want to run tail pipes on my 77 maverick what are you guys using and iam a little worreid about the drivers side looks like it will be tight to the gas tank the car has 351w holly systemmax 202 heads 292d 534 lift cam with long tube headers
  2. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    It is tight, but any decent exhaust shop can do it. I'm running 2 1/4 duals.
  3. maverick75
    Run them around the springs like they do in Camaros, between the tank and spring there is no room on the drivers side when using a large 75-77 fuel tank.
    [​IMG][​IMG]
  4. maverick75
    In 75 they started using a larger fuel tank that is heavily offset to the drivers side, on your 73's it's a different story.
  5. 71gold
    2.25"...exit behind the rear tires...:chirp:
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    +1 Or even 2-1/2" (tailpipes, not entire system).
  7. predfan2001
    I agree with that. I don't like seeing exhaust pipes coming out the rear anymore unless it's a car that has factory cutouts.
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    No offense to others.. but IMHO.. bending 2.25 inch piping around the rear axle on a larger cammed motor like that would be a wasteful endeavor.
    Of course you should use mandrel bent tubing to maximize flow/reduce back pressure around bends.. but even mandrel bent 2.25 inch piping will become more of a burden for the motor to push around all those bends when it comes up on the cam.
    Maybe it(2.25) would be well enough for a smaller 302.. but even then.. if it had some compression/larger cam and I wanted to bend the bejeezus out of it to push it all the way to the rear?.. I'd still lean towards 2.5 inch piping. Then again.. I'm all about those last few high rpm horsies that some don't mind leaving on the table. That motor will be down an easy 12 horse with only a few lbs of torque increase up to about 2,000 rpm on a motor combo like that. Possibly even more lost if you're running 10.5 compression or higher.
  9. Dave B
    Like this?
  10. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    i like that dave, got a pic of the other side?
