Tail light help
Discussion in 'Technical' started by Eboe, May 4, 2011.
  1. Eboe
    Eboe Member
    Lebanon, Or
    I have a 1970 maverick and my break light went out the other day and when I tried to replace it the bulb wont fit into the housing any more. I think the two springed connector points are stuck in the down position so the bulb is loose in the housing. Is there and eazy way to fix this or do I have to replace the whole housing?
  2. jmgford
    jmgford Member
    Iowa
    Try some light penetrating oil in the socket, like PB Blaster. Let it soak awhile and then try working the spring-loaded contact to free it up. If there is any visible corrosion, try to clean it ourwith a small pick.
