t5 swap
Discussion in 'Transmissions' started by 70 maverick, Dec 4, 2010.
  1. 70 maverick
    70 maverick Member
    Ajo, AZ
    1970 Ford Maverick, 76 Mav for parts
    Hi everyone my name is Chad and im putting a 5.0 out of a 2000 ford explorer in my maverick. Im using a painless wiring harness and im going to use a t5 tranny from an 88 mustang gt. I was wondering what headers everyone was using with their 302/t5 setup and if they fit with or without mods? Any info would be great! Thanks
  2. brainsboy
    brainsboy Member
    Tampa
    I think most people are using the hooker 6901's
    greengt429 likes this.
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    but chad has already did the t5 swap and has headers on his 70 maverick
    p.s my name is chad too:dancing:
    forgot to add that i have the summit brand headers in my maverick
  4. mean_maverick
    couldnt get long tubes to fit in my car with the engine/trans (5.0/T5) already installed...
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Isn't he going to run into the GT40P head with headers issue?
  6. bmcdaniel
    The instructions from my 6901s say you have to jack up the engine and install from underneath. Mine went in easily that way.
  7. bmcdaniel
    The trans tunnel is smaller in a 70. I had to split open the top of the tunnel and add metal to make room for the T5's shifter tube.
  8. 302-72-mav
    302-72-mav Member
    sactown CA
  9. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I used Headmans slipped right in.
  10. 70 maverick
    70 maverick Member
    Ajo, AZ
    the trans tunnel is not an issue since my car had a 460 and a toploader trans in it before i got it so its already cut up. and my shock towers are shaved so i have more room. my only concern is interference with the gearbox and the trans?
  11. 70 maverick
    70 maverick Member
    Ajo, AZ
    here's a pic you can kinda see how much more room there is
  12. 302-72-mav
    302-72-mav Member
    sactown CA
    HEY you know that thoes heads are GT40-P heads and you have to use special headers with them because of the spark plug angle or every time you runit fo 10 minits you will have to put new plug wires on the motor because it burns them
    somone on the board sed to use 2 flanges on each side ?
    and how i know they are the P heads is because there are 4 lines on the END of the head and the regular non P heads have 3 lines
    do a search about them
  13. bmcdaniel
    I ran P heads on mine for years with an old set of Blackjack long tubes. Accel shorty plugs on the driver's side and 90* plug boots from an electronic distributor cap.
  14. bmcdaniel
    On mine the shifter tube, not the shifter tower, hit the tunnel forward of the brace. I had to split it open.
  15. 70 maverick
    70 maverick Member
    Ajo, AZ
    do you remember what part number they were and blackjack is made by dynomax right?
