t-5 conversion
Discussion in 'General Maverick/Comet' started by OLD GOOSE, Aug 5, 2012.
  1. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    I was reading the t-5 conversion and it doesn't say anything about what they did for the driveshaft what does everyone do with this swap? what parts used etc.
  2. 71gold
    we used the...stock length... maverick driveshaft for Earls...
  3. MrP
    MrP Member
    1970 Maverick 302
    I am trying to figure out the same list.
    Franks crossmember
    Way to mount a pedal to the brake assembly with the mustang steve quadrant cable and adjuster.
    86+ 5.0 mustang entire trans from flywheel tailshaft yoke. This way I have everything!
  4. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    that's what i used:yup: the T5 is a inch or so longer then the c4/3 speed but it still works
  5. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    thanks sounds simple enough
  6. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    I got a custom flywheel, Mustang steve quadrant, cable and cable stop, and a maverick clutch pedel assembly
  7. Steven Harris
    Steven Harris Member
    Swap from six cylinder, 3 speed standard column shift:
    Complete 91 Fox Mustang 5.0 with T-5 and EFI.
    Mustang Steve's quadrant, clutch cable, Hooker headers. I made the crossmember and used the stock driveshaft.
  8. injectedmav
    injectedmav Member
    Georgia
    I shortened mine.
    I used the Mustang quadrant and modified the Maverick pedal bracket to accept it. I also reinforced the firewall by installing a plate behind the brake master cylinder after finding the limitations of the stock sheet metal.(where the cable mounts)
    I made the crossmember.
  9. YotaRacer
    YotaRacer Member
    Gloucester VA.
    75 Grabber
    I used the hydraulic clutch setup from modern driveline. Driveshaft is out of a fox body stang. I must admit I didnt even try to put my stock driveline back in.
  10. bmcdaniel
    bmcdaniel Senile Member
    I had a shaft custom made. Your ride height will have some effect on how much engagement the slip yoke has in the trans.
