suspension problem
Discussion in 'Technical' started by maverick93, Jan 30, 2013.
  1. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    Has anyone else had a problem with two coils cut off of there springs? every time i hit a bump there is a loud almost bottoming out sound but the cars not THAT low at all. any ideas or has anybody else had a similar problem?
  2. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Are your shocks good. If not this could cause you to bottom out.No seal around the piston cylinder.
  3. Bryant
    are the bump stops for the upper control arm still there? they are on the piece that surrounds the spring in the fender.
  4. rthomas771
    No problem at all...but they are new springs. Rides like a new car.
  5. Craig Selvey
    Post up a picture.
  6. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    the first thing im gonna do is get some front shocks. Most everything is new in the front since the disc brake conversion a couple months ago.
  7. mercgt73
    put a dab of grease on the bump stop. repeat the noise. and then see if the grease is squished. if so, you are bottoming out.
  8. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    okay, thanks for the suggestions guys, I actually haven't really noticed a bump stop in the front end :eek: I'll get it all checked out.
  9. Bryant
    with out the bump stop, you will get a very harsh bottoming out feel when the control arm hits the cover around the spring.
  10. Streamliner
    Streamliner Member
    2 coils sounds like a lot
  11. 71gold
    how big of a bump are you talking?
  12. rthomas771
    I cut 2 coils off a set of new Moog-8304 springs 3 years ago and this is how it looks today.
  13. Streamliner
    Streamliner Member
    It must've had nose bleeds before
  14. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    not really big bumps at all, even slowly over a speed bump.
  15. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    I had a rear shock come off the top mount and it would sometimes sound like it was bottoming out. Drove it like that for almost a year and noticed it finally when I bolted on my rear sway bar.
