Stuck passenger door
Discussion in 'Technical' started by Wilsond3010, Apr 14, 2012.
  1. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    Wondering if any one has a easy way or advise for a stuck door
    The door unlocks with the key but won't open from inside or outside
    How do I get the panels off without opening the door itself any big gotchas I should be watching for?
  2. Craig Selvey
    That is going to be a tough one.
    If it was me, I would remove the front seat, then remove the door panel and take a look-see and see what the problem is. You might be able to get the door panel off with the seat in place. Either way, the door panel needs to come off.
  3. grindfactor
    grindfactor Member
    South Carolina
    1972 Ford Maverick
    I had this problem one time. I had locked the passenger door and then unlocked it and never could get it open again. Fought with it for awhile. Then one day I locked it again and pushed the lock tab on the inside down. Turns out it wasn't locking all the way and somehow that kept it from coming unlocked.
  4. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    Thanks tried that and nothing. Also noticed previous own must have tried to get panel of it's got a slight rip
  5. Wilsond3010
    Wilsond3010 Member
    Regina, SK
    1970 Maverivck
    finally the door is working for now but will look and stripping the mechanism and cleaning it properly
    Got the right socket driver and panel tool from princess auto and then from inside could see everything moving so sprayed with penetrant lube and now it works
    Thanks for all help and advise sorry I know been asking so much on the forum
  6. Mav71
    Mav71 New Member
    1971 maverick
    Don't feel bad about asking, everyone is here to learn and share :thumbs2:
    Glad to hear you got the problem fixed, I had the same issue and did what you did took it apart and cleaned and re-lubed all the internal mech's working great now!
