Does anyone know exactly what needs to be done to your block if you order a 331/347 stroker rorating assembly? I am curious as to what needs to be done to the block. Thanks Steve
For a 347 the cylinders are usually bored .030" oversize and notches need to be ground at the bottom of the cylinders to clear the rod caps. Not sure about a 331.
