Steering wheel shakes at high speed
Discussion in 'Technical' started by Lingwendil, Apr 19, 2010.
  1. Lingwendil
    Lingwendil Member
    Turlock, California
    Okay, sometimes when i'm driving, and only between 35~50MPH, my steering wheel starts to rattle/shake and you can feel it in the whole dash. The car is a 71 auto mav, if it matters. I jacked the car into the air and checked my steering/suspension and everything is nice and tight. It is strange because it is intermittent and only at speed, and only started a few days ago. I got my front wheels re balanced and it made no difference.
  2. blugene
    Sounds like a possible tire seperation. It could also be a caster angle that moves under road force/load. Could be a number of things. How do the rod bushings look?
  3. Lingwendil
    Lingwendil Member
    Turlock, California
    the bushing look great, and it is intermittent only at around 35~50mph.
  4. MikeG747
    MikeG747 Member
    Arkansas
    Had the exact thing happen on my son's 72 Comet. Ended up being the transmission mount. I would check that out. Good luck. (y)
  5. 302-72-mav
    302-72-mav Member
    sactown CA
    my truck had the same problem it turned out to be the drive line AFTER it messed up the tail shaft on my trans had to get a new trans ??
    you can take the drive line to a shop and they will check to see if it will need to be balanced for FREE at least they did it at the shop by me
  6. baddad457
    Either you've got a bent wheel, a tire separating or one of the front wheel/tires is out of balance.
  7. Mavman72
    Does your car have power steering??? The hydraulic ram will cause this if it is used out.
  8. Lingwendil
    Lingwendil Member
    Turlock, California
    no power steering, and its raining so ill check the other stuff later.
