Steering column bushing
Discussion in 'Technical' started by okibono, Apr 29, 2007.
  1. okibono
    okibono Member
    cali
    What is everyone useing for their rebuilt steering column? I know there is some type of bushing that goes around the shaft that the rag joint bolts to, and allows that shaft to slide up within the outer shaft w/o play.
    What bushing is that, and what does it look like? Oh, and where can I get it?
    Is it that $14 dollar bushing that AK has?
    thanks!(y)
  2. okibono
    okibono Member
    cali
    anyone?
  3. Craig Selvey
    I never rebuild a steering column. Never needed to. I would see no real need to rebuild it.
  4. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Not sure on the part #. I have seen the bottom bushing or bearing (thinking it's a bearing) If it's good, you should be able to push back up and carefully peen the outer housing to keep from falling out. Will try and look at one and see if I can better for you.
