Steering column bolts??
Discussion in 'Technical' started by HarleyGA, Nov 23, 2014.
  1. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    I'm trying to figure out how the steering column bolts up under the dash. The diagram I have looks like there should be a stove bolt coming down from the top through the aluminum spacer but the square opening on the top bracket looks too large for a conventional stove bolt. What kind of hardware should I be looking for?
  2. baddad457
    It is a square headed bolt, just not your typical hardware store bolt. It's a 3/8"NC thread bolt about an inch long or so, the nut is an integral washered nut, knurled on it's face to lock it in place when tightened
  3. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Thanks baddad I am amazed by the variety of fasteners Ford used to build such a basic car. Unless someone out there has a pair they can part with i'll have to improvise.
  4. Craig Selvey
    I probably have the bolts. Can you post up a picture of what your underdash looks like. I think the bolts should be on the brake pedal mount.
