was there ever a floor shift 69' searing column, (the on with the key in the dash? if so does anyone have one they want to see?
I used a 69 Mustang column in my 69.5 69 Stangs had key on dash and shifter on floor. The column bolts right in place using the Maverick mounting plates. I can't say for sure if it bolts directly to the stock steering box or not. I adapted the bottom of the Mustang column to run through a fire wall bearing and then 3/4 tubing and Sweet u-joints to my Mustang II rack.
View attachment 55436 View attachment 55437 View attachment 55438 View attachment 55439 View attachment 55440 The long tube column is a Falcon column for floor shifter. It does not have the steering shaft. It may work with some fabrication. The other two are 1969 1/2 Maverick. One three on the tree and the other for column shift automatic. PM if interested. I'll take $50.00 plus shipping. Rick
yeah i can tell haaa, i have very little, my maverick has parts from, 74,73,72,70, now im planing a few 69 things
I have alot. And I am cleaning out and selling most parts cheap. I need to clean my yard and work on my project. Rick
I know what you're saying Cleveland, toploader and 9 inch center section all of of my 72 Gran Torino Sport - 9 inch rear housing out of Lincoln Versailles - rear Jeep rotors with 84 Chevy calipers from a C-20 truck - front are 11 inch Granada rotors with Metric Chevy calipers on Mustang II spindles - 72 trans tunnel and clutch pedals - etc - my list is a mile long
same here, as you see by my picture it started as a 74, im putting quarter panels on it from a 73, the bumpers from a 72, the floor board and trunk pan from the 72. (the 72 i nicknamed patches haaa) also the 72 had a good cowl that fixed the 74, the 9 in is from a ranchero front brakes are from a versalies the enging is from a Lincoln mark 5 or something maybe a mark 7 cant remember, its an 86 HO tho,i have the clear lenses which are 1970 right?
