Starter run on..........
Discussion in 'Technical' started by mrcomet, Nov 26, 2016.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Went out to start up the Comet today and the starter kept running on after the engine fired up. I turned the key to the off position and the engine stopped but the starter would not disengage. I had to pull the negative battery lead to stop it.
    Not being a mechanic I'm thinking of three possibilities. 1) Bad starter, 2) Starter Solenoid, 3) Ignition switch.
    Am I in the right ball park about this. Anyone else have this issue and solved it.
    Appreciate the help and advice.
    Thanks!
  2. Krazy Comet
    Probably 99% of the time it's the solenoid that has stuck contacts... Whack it with a screwdriver handle and see if that fixes it..
    rotorr22 and 71gold like this.
  3. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Thank Krazy Komet!!. The solenoid was the problem. Put a new one on this morning and I'm Willie Nelson. (On the road again....)
    By they way can you recommend where to get a new manufactured high quality solenoid. These re-mans suck. Also I have a re-man starter from NAPA. Any advice on where to also get a new manufactured high quality starter.
    Thanks!
  4. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    Go with a mini torque starter! But I normally go to car shows and find NOS starter soloniod for sale.
