Stalls easily without exhaust installed. Run better with it?
Discussion in 'General Maverick/Comet' started by scooper77515, Feb 21, 2014.
  1. scooper77515
    Even after it warms up, it wants to stall when I give it gas from a takeoff. I have to give it a little extra gas as I take my foot off the brake (using both feet) or it will stall on me. Then it peels out on takeoff.
    Currently driving with open headers, and wondering if this will go away after I get full exhaust installed?
    Timing is great, haven't messed with any carb settings since before I tore the suspension out. Idles nice and smooth.
    Only other thing I can think is maybe the gas is too old? It is at least a year old, and been sitting without running for almost a year.
    Also idling around 550 rpms. Maybe bump that up a hundred or so?
    Dropped off for exhaust installation yesterday, hope to get it back today and see if it runs better...
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    It could be from the open headers breathing a lot better then a full exhaust and leaning out. Could also be old gas, idle does sound low but I'm no expert. I think most people set idle for 650-700 in gear and about 900-1000 in park, probably also depends on the cam for idle speed.
  3. scooper77515
    In the past, I have kept the idle at 550 in gear. So it lopes and rocks the car at red lights. I like when it does that!
    I was thinking it was a lean out condition.
    Muffler guy wants to keep it another night. Taking his time on it so it looks good.
  4. simple man
    simple man Member
    Bunnell,Florida
    If you have year old gas, you're lucky to have the car even start! I wouldn't adjust anything until you drain and refill with new gas (non alcohol, preferably) and drive at least 20mi or so to get all the old stuff run out of the system. :)
  5. Mavman72
    Once you have an exhaust system on it...The problem will I say "Most likely" go away. Free flowing open headers change the way the engine scavenges, affects vacuum signal at carb and current ignition timeing set up. You really should turn the idle up to around 700 in drive though. Could be gas is stale or there is a dead horse (Junk) in the carb from sitting. The ethanol in the fuel wreaks havoc with fuel systems. Especially in cars that sit for prolonged periods of time. See how it behaves once you have it back with exhaust on it.
  6. mighty76
    mighty76 Member
    calgary,alberta canada
    76 maverick,58 ford f250, 79 f150 stepside 4x4
    you are leaned out with open exhaust, idle is a bit low, and just me personally, go with a different intake,
  7. scooper77515
    Would it make any difference whatsoever if the tank was full of Super?
    That is all I run...just in case.
    Does 92 octane last any longer?
    Not sure, but I "may" have added Sta-bil into the tank before I stopped driving, assuming that I would not be driving again for a few months.
  8. Angryeyes
    Angryeyes Member
    Canada
    Mercury comet, chrysler 300, Kawasaki ninja 600
    Im no chemist but I dont think the octane levels of a fuel has any bearing on how long it takes before it breaks down. I say flush it and Start it up with fresh fuel. May as well eliminate one thing at a time
  9. scooper77515
    Well, if fuel is the issue, then I refuse to drain a 3/4 tank as junk.
    I will just drive the snot out of it until it is empty and top it back off with fresh.
    If I get the car back tomorrow...might have a long trip to burn it off.
  10. mighty76
    mighty76 Member
    all gas starts to loose octane after about 6 mnths, i think after you get full exhaust on, re-set carb and timing, you should be good,and maybe change plugs
  11. mojo
    mojo "Everett"- Senior Citizen
    I wud not do anything till I get exhaust done and C how it works.
  12. Krazy Comet
    Gas that's a little stale won't likely cause hesitation, unless it smells rancid, I'd idle it up and drive it...
    Running open headers usually requires at least three or four jet size increase, as already mentioned without back pressure scavenging, is far better...
  13. scooper77515
    Plugs are new. I wont touch any settings until I get exhaust on, and run a clean tank.
    I spent WAY too much time tuning that carb to get it right, to go and screw it up on bad gas and no exhaust.
  14. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    Make sure you check that gas M P G HA HA
  15. mighty76
    mighty76 Member
    ya might wanna stick a vacuum gauge on her to, a small leak caused me a lot of pain, till i found it,
