Stalling @#&*
Discussion in 'Technical' started by BadBrad73, Sep 30, 2005.
  1. BadBrad73
    BadBrad73 Member
    Rome, GA
    1973 Maverick
    1973 Maverick 250/ C4, Holley 5200 on an adapter, DSII, 6 into 1 header with Y pipe and dual generic flow masters.
    The car runs great....MOST of the time. It does sometimes stall though or slowly die and goes dead. It does this driving along at any speed or condition, doesn't seem to be temperature related as it can happen within the first mile. After the engine begins to stall you can let off and sometimes it will return to idle, sometimes not. If you stop, it will always restart immediately but will stall again in only a few feet. It normally does this 2 to 3 times then runs normally again, maybe for a few days at a time. Any ideas? It has a new carburetor that runs great, new fuel pump, rubber lines, fuel filter and new plugs. All of the ignition components were installed "used" from a donar car and had previously given good service.
    Could this be ignition related eventhough it "feels" like fuel?
    Thanks for any help guys.
    Brad
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    sounds as it may be something in the tank, that happened with my 71 gray 200 until i got my tank cleaned. :hmmm:
  3. Halebopp
    Halebopp Member
    Ankeny Iowa
    Is your gas cap venting properly? take it off and see if it still stalls.
  4. Mavaholic
    71 & up Mavericks and Comets do not have vented caps. However if there is a block in the vapor line, this will give you the same results.
  5. sierra grabber
    northern nevada
    I dont know about brads, but that didnt help with mine. i even tried running with the cap off for a test. the intermittent thing was because the junk would cover the whole when i was going or climbing a slight hill, then stop blocking it when i slowed and stopped. it would happen randomly too, sometimes the junk would cover the outlet, sometimes it wouldnt.definately stopped when i got the tank boiled at a radiator shop.
  6. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    With all the recent changes, it might be hard to track down. I would start by removing the carb and using the one old one (assuming then engine was running with it on) or maybe borrow someone's.
    Next, I'd start replacing electrical items ONE at a time with the old ones (if still available).
    Do you smell raw gas when it gives you the problems?
    I'd also pull the plugs and try to read them (or at least compare them to each other).
    Just my thoughts. 'Hope you find the demon soon.
  7. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Next time it dies on you and won't start right back up, jump out and pull a plug wire off, stick a screw-driver in it and turn the engine over and see if it has fire.
    Then go from there
    clint
  8. stmanser
    Davenport, Iowa
    the same exact problem with mine...i spent some money trying to figure it out....and finally....
    the coil was going out....sometimes it would spark.....drive just fine...then not spark and die....hit the gas while it was doing this would cause it to sputter and die or not...but it would die...puch clutch in....turn key...fires up...sometiems dies...sometimes not...
    replace your coil....
  9. 71gold
    i had a .."clear glass fuel filter".. do the same thing...frank...:bouncy:
  10. tommyboy
    tommyboy 77 mav
    parkersburg west virginia
    1977 maverick
    mine did the same thing and i changed everything to do with fuel but found out it was the selanoid (dont think its spelled right) changed it and hasnt stopped yet
  11. Jamie Miles
    Alto, GA
    I've had a few
    Mine did the same thing with a fuel pump going out. Just to add to the list. :)
  12. sierra grabber
    northern nevada
    If it is electrical, my money would be on the coil. course being a ford, 20 dollars for a solenoid and 5 minutes to change(y)
  13. stmanser
    Davenport, Iowa
    solenoids out here are about 9.99 and yeah...easy to change....
    like i said...i spent alot of money...
    solenoid.. cables... spark plugs, fuel pump, fuel filter, etc etc etc... finally it was the coil...
    of course just like everyone always says....you cant be absolutly sure without seeing the car and seeing the problem in action....
    all you can do it elimate possible causes until it works right and you will know that was the last fix you needed...
    good luck....
    but keep it simple... look at the most obvious first... rememebr...you must have spark and fuel for fire...
  14. BadBrad73
    BadBrad73 Member
    Rome, GA
    1973 Maverick
    Thanks guys. I may put a coil on it and see how it goes. Lots of good ideas. Again, thanks.
    Brad
  15. BadBrad73
    BadBrad73 Member
    Rome, GA
    1973 Maverick
    Ok, for good or ill I put a new ignition module (DSII) on the car last Friday. No problems since (knock on wood). If the problem resurfaces I'll let you guys know.
    BRad
