Spring Perches and Shocks
Discussion in 'General Maverick/Comet' started by sanders739, Aug 23, 2011.
  1. sanders739
    sanders739 Member
    Washington St.
    72 4dr, 70 2dr, 75 4dr
    So I installed roller spring perches and went to install my shocks and they are too short now????? Anybody else run into this problem.:huh:
  2. Resto
    Resto Benders Evil Twin
    Yuma AZ
    Not yet but id like to see a picture of them.
  3. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Whay do you say they are too short now? Think its normal for the shocks to limit spring travel.
  4. rthomas771
    Only time I had that problem the car was still on jackstands
  5. sanders739
    sanders739 Member
    Washington St.
    The bolts at the end of the shock that go through the perch barely clear the perch, and there's certainly not enough room to install the bushing and washer.....but i do have the car on jack stands
  6. Jsarnold
    '72 Sprint
    You need to have the weight of the car on the front wheels to compress the springs. Do you have ramps?
  7. mercgt73
    mercgt73 Member
    Or take your jack with a block of wood and slowly raise the lower control arm.
  8. Dave B
    You should be able to install the shocks with the car on the ground, just turn the wheel to the side, so you can get in there.
  9. Jsarnold
    '72 Sprint
    I admit to being a worrier when it comes to working under cars on jack stands. Seems like it could get kinda unstable when you take the weight off the jack stands and start wrenching on it. I always give the car a good shake before crawling under it.
  10. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I had the same problem. I replaced the spring perch and the shocks would not go in the lower arm. I used a floor jack to raise the lower arm and it works.
  11. Canuck
    Canuck Member
    Calgary, Alberta Canada
    1973 Comet
    I agree with the other posts. You need to raise up the lower arm with a floor jack until the shock is through far enough.
  12. sanders739
    sanders739 Member
    Washington St.
    Nice....thanks guys...i'll get on it tonight
  13. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Yeah, the shock acts like a travel limiter on these cars. Not the smartest idea Ford ever had.
