Spring Insulators and Perch Saddle
Discussion in 'Parts Interchange' started by njnjtek, Oct 18, 2003.
  1. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    I need to know what insulators will work in my 76 Maverick… I think I can use Mustang Parts… but as to what year of Mustang I don’t really know…
    So what Years of Mustangs are compatible with Mavericks?
  2. Mavaholic
    64-73 are all the same for the Mustangs and our cars
  3. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    THANKS
  4. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    Auto Krafters has the correct spring insulators for Mavericks cheap. I bought a set.
  5. comet dad
    comet dad Member
    Longview, Texas
    1974 Mercury Comet
    just recieved
    mavaholic listed the part #'s in another thread here from CJ pony parts......I just recieved them yesterday......$51 for both spring insulators and perch saddles both sides delivered.......part #'s CSI1 for insulators and CSS for spring saddle
    1-800-888-6473 or web site .........Robert....... let us know how it turns out
  6. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    When I replace the spring insulators and the perch saddles… is there anything else I should do while I have the springs out? What should I look for?
    Thanks for all the info people….
  7. Mavaholic
    You have to remove the springs to replace the upper A frame bushings. So if yours are original, it mught be a good time to do it now. If yours are ok, at least remove the 2 nuts and pop the a arm out and put 90 degree fittings in.
  8. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    can you explain more
  9. Mavaholic
    If you look under the hood, down at the shock towers. There are 2 nuts on each side. These hold the upper control arm in place. DO NOT REMOVE THESE NUTS UNLESS THE SPRING IS REMOVED FIRST!!!!! DO NOT REMOVE THESE NUTS UNLESS THE SPRING IS REMOVED FIRST!!!!! DO NOT REMOVE THESE NUTS UNLESS THE SPRING IS REMOVED FIRST!!!!! Get it? Once you remove the upper control arm. There is a bushing on each end. Looks like a big nut. These usually dry out and start squeeking and drive you nuts. Replace them and/or put 90 degree grease fittings on them so they can be lubricated. Most cars probably have access holes drilled, cut or gouged in the shock tower to gain access. If yours dont, put the fittings in.
  10. Craig Selvey
    The only thing I can add is: DO NOT REMOVE THESE NUTS UNLESS THE SPRING IS REMOVED FIRST!!!!!
  11. njnjtek
    njnjtek Member
    Canada
    1976 Maverick
    Everything is clear except for the....
    These grease fittings… How do I attach them to the insulators?
  12. Mavaholic
    There is a little cap on each end of the bushings. Just unscrew it and put a grease fitting in its place.
  13. 357 Grabber
    357 Grabber Maverick DieHard
    kentucky
    2 71 grabbers,72 Maverick , son has a 73 maverick
    on a side note IF you want heavier front springs ( i put a windsor in mine so I did some research ) the 250 6 cylinder front springs have a higher spring rate than the v-8 springs do FYI
  14. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    if you install the grease fittings and lubricate them do the bushings still need to be replaced or are they fine just with grease?
  15. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    nevermind... I'm just going to return the bushings and ball joints and order whole new upper arms to make life simple.
