Sport steering wheel restoration
Discussion in 'General Maverick/Comet' started by facelessnumber, Jul 2, 2012.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Last week I went plundering through a junkyard looking for a Mustang with an aluminum driveshaft. Didn't find it. But I did find a Mustang II with a sport steering wheel!
    It's leather wrapped, and of course the leather is trash, but it seems the leather has preserved the material underneath very well. I haven't peeled it all off but in the area where I did, it looks like it will clean up very nice!
    It's got some rust spots on the spokes. I figure since it originally had a brushed finish, I could probably make quick work of it with a wire wheel in a die grinder. I think that would bring it back to a clean, brilliant shine and restore the brushed finish as well. Am I on the right track here?
    Now the down side... The steering wheel itself is all I have. No horn button. it does have the contacts for a horn. Is the horn button assembly unique to these steering wheels, or are there other ones I can be looking for?
    I'll see if I can remember to take some pics tonight...
  2. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Next time you are looking for a Mustang with an aluminum driveshaft you should go look at the minivans. the 80-early 90s suqare body All Wheel Drive Aerostars have an aluminum driveshaft that is a direct swap for a fox body mustang, which should also make a good swap for a maverick. Would just have to change the rear u-joint. They arent as hard to find as you would think. But if you cant find one then you could use a rear wheel drive aerostar axle, which is longer, and have it cut to size and balanced. Still cheaper then a new aluminum shaft.
    BTW, good luck with the steering wheel.
  3. facelessnumber
    Memphis, TN
    '71 Grabber
    Thanks! Yeah, I was also looking out for the AWD Aeros. Found plenty of 2WD but no AWD ones.
  4. tody
    tody Member
    cologne, germany
  5. facelessnumber
    Memphis, TN
    '71 Grabber
  6. facelessnumber
    Memphis, TN
    '71 Grabber
    Am I right in assuming the material under the leather is presentable in its own right after it's cleaned up, or should I also be looking to put new leather on it?
  7. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    Check with Juliano's in Rockville, Ct. They can rewrap your steering wheel.
  8. Dave B
    You can buy some of the parts for those horn buttons, at NPD. I don't know if they actually have the switch or not, but they have the silver plastic outer ring, then again they are 85 bucks.
  9. Earl Branham
    Lugoff, SC
    Get hold of this guy....in Phoenix City, AL. He specializes in Mll and nothing else. He has horn buttons and everything else you will need. Got mine there.
    Phil Schmidt
    218 Wright Rd
    Phoenix City, AL 36869
    Ph: 334-298-3038
    pschmidt65@prodigy.net
    Web site: www.mustangii.net/parts_specialty.asp
  10. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Instead of a wire brush I'd use a SOS pad and /or maybe a scotchbrite pad.
  11. facelessnumber
    Memphis, TN
    '71 Grabber
    Cool. Thanks for the suggestions. I'll get to cleaning on it when I have time, and depending on how nice I can get it I'll start looking into horn buttons and re-wrapping after that.
  12. rayzorsharp
    Dang! I picked up a real nice Sport wheel a couple years ago that needs only that silver ring. I can't bring myself to pay more for the ring than I did for the entire wheel though. :cry:
    I'll just have to keep an eye out on eBay for one. Bound to find one soon if I really start trying.
  13. rthomas771
    I bought a sports wheel at a swap meet earlier this year too. It took about 10 minutes to clean the spokes with a Dremel and brown scrub pad bit. Go slow speed with the Dremel or it will sling the pad apart. I know nothing about leather restoration but now I need to learn something about it soon. I’m hoping it doesn’t need replaced. Here’s a pic showing the worst spot.
