Sparkplug gap (idle change)
Discussion in 'Technical' started by Blue Brick, Sep 18, 2012.
  1. Blue Brick
    Blue Brick Member
    Can changing sparkplug gap increase and decrease idle? Thanks.
  2. groberts101
    groberts101 Member
    Minneapolis, MN
    yes it could slightly.
    Has the same effect as changing timing and/or mixture burn to some small degree. Which ultimately means that air bleeds should always be adjusted again if spark gap changes.
  3. Blue Brick
    Blue Brick Member
    Thanks.....
