sound proofing
Discussion in 'Technical' started by Racer_X, Feb 23, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    dose anyone know of any sound proofing material thats just as effective but cheaper than dynamat?
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Search the board for peel n seal
  3. mojo
  4. Racer_X
    North Carolina
    thanx found it, gonna see if my local lowes has it.
  5. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    I used Peel n Seal also. I even went up the back and over the rear dash to keep road noise from coming from the trunk area and went in and covered the interior of the rear wheel wells to keep that noise down. Went up as far as I could on the front fire wall area too.
  6. don graham
    If Lowes doesn't have it in stock you might check and see if they'll order it for you.:)
  7. Stefan
    Montreal, QC
    I fixed the image link so it no longer shows the user who clicked on the image their own gallery.
  8. mojo
    Thank You!
  9. captainmack
    captainmack Quad Door
    All those products are waaaay overpriced / hyped.
    Two ways to reduce noise. Absorb it or reflect it.
    The road engine noise is very low frequency, and is the hardest to stop the transmission of. It cannot be reflected so it must be absorbed. SHEET LEAD is the best, but heavy! In engine rooms or generators, 1" sheet lead/foam/mylar is used. In music recording studios, very thick 1' or more insulation is used which obviously there is no room for in a car. As a cheap substitute for sheet lead, dense butyl rubber sheet is used. that is what dyna mat is. It is a poor substitute. You can buy this material at Home Depot much cheaper, it just doesnt have a sticky back and a cool Chip Foose Dyna Mat label.
    First, stabilizing the sheet metal is very important so whatever you use must contact tightly the metal. I used both the 1" Marine lead foam sheet, and a ceramic paint on coating which I built up to 3/4", which I was able to apply in side doors/etc. where the butyl rubber fat mat would be impossible.
    BTW, the Fat Mat/ Dyna Mat is very time consuming to apply correctly, trust me I've done it. Use two layers of it if you go that way.
  10. Dave B
    3/4" ?? Is it bulletproof?
  11. captainmack
    ha ha!! I meant 3/8"... yeah that would be bullet proof.. :)
  12. 71gold
    got a link to this stuff...and how hard was it to... paint 3/8" thick?
  13. captainmack
    Its Noxudol 3101. It can be sprayed but it is a mess. I use throw away brushes and several coats to achieve desired thickness.... it is like painting thin concrete and dries as such. It is water based, but has a very strong ammonia smell so respirator mask is a must. When dry it is like concrete.
    http://www.soshinusa.com/noxudol.asp (bought from)
    http://www.maritimeequipment.com/ShowAd.aspx?id=100215
    http://www.noxudolusa.com/
    http://www.cyber-bridge-marine.com/Engine-Room-Vinyl-Foam-Soundproofing.html
    other info
    http://www.allnoisecontrol.com/products/MarineAcoustics/MarineAcousticInsulation.cfm
    http://www.frontendaudio.com/Auralex-SheetBlok-Vinyl-Sound-Barrier-4-x-10-p/1510.htm
    http://www.acousticalsolutions.com/audioseal-sound-barrier
    http://www.soundprooffoam.com/quiet-barrier.html
  14. 71gold
    does/will it crack?
    Noudol 3100/3101
    Noxudol 3100/3101 is a waterborne viscous, elastic sound damping paste based on polymer. Due to its viscous elastic flexibility it converts sound producing resonance into heat...:huh:
  15. captainmack
    no crack. crack kills:naughty:
    it dries very hard yet is very tenacious, and can flex on sheetmetal. I believe it to be much lighter as well.
    Sound is vibrating air... vibrations are energy.. reduced to inaudible heat..
