Somethings Not Right Here!
Discussion in 'Technical' started by Scotty P, Jul 18, 2005.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    Are you guys sure this conversion really fits?
  2. don graham
    i see what's wrong. you should be putting it in through the other end.:biglaugh:
  3. Scotty P
    Scotty P Member
    santa rosa, ca
    I tried, the rear seat was in the way.. Thought it was a corvair! At least I had some help!
  4. don graham
    scotty, if that's your wife she looks like she has serious doubts about this project. i usually make my wife lay under the car to guide the engine in. :)
  5. Scotty P
    Scotty P Member
    santa rosa, ca
    Who do you think rebuilt the u-joints!
  6. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I guess I just don't get the whole 'put it in all at once' process.
    Maybe it's because most everything I have ever worked on I didn't
    want to scratch. I have helped put motor/tranny combos in before
    all at once. It is more of a PIA to me than engine from the top and
    tranny from the bottom. I guess it's just a preference thing.
    Do people have that much trouble getting a tranny in that they would
    risk beating and banging the firewall, shock towers and radiator support?
    Just me I guess?
    That looks good Scotty. What kind of heads do you have on there?
    Seth
  7. Scotty P
    Scotty P Member
    santa rosa, ca
    Edelbrock RPMs. I rebuilt the tranny at the same time. I really do not like the whole lining up of the converter, bellhousing etc.. I did not scratch the firewall or the bellhousing paint doing it this way. It does take two though. I could do just the engine solo..Say a friend take out the windsheild of his mustang once though doing it this way!
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    Of course Seth, mine are not near as perfect as yours..
  9. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Great Scott! :eek: (have you heard that one before?)
    Very nice. I too have my engine bay setup to remove the motor and tranny together ('modified the radiator support to be removable. That, combined with the removal of the grill - it should be a snap).
  10. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    littleredtoy I agree with you, its much easier to put the engine in then go under and put the trans in, especially if its an automatic! as well as the scratches and not wanting to bend and sheet metal, nice looking engine though.
  11. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    Scotty, Mine is far from perfect. I just see so many potential hazards
    from doing it that way. Those RPM's are nice. I don't have them but a
    friend does with about the same pistons and cam as I have and there
    is quite a difference. Post more pics on the progress when it's in there.
    Seth
  12. Jamie Miles
    I put the engine and trans back in together in the '74. You just gotta go slow and have someone else down below guideing the trans in.
    Next time I'll pull them seperately and put them back in together. Pulling them out together was a major PITA.
  13. Scotty P
    Scotty P Member
    santa rosa, ca
    Seth, it is in there. Took 54 minutes from start to finish. Although, I still need to change these "bolts"
  14. 4dr73mav
    4dr73mav Member
    Weld County Colorado
    1973 4dr Mav V8
    I see that your thermostat spring is facing out of the intake. Is that normal on those engines?
    Jonathan
  15. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Good eye! The thermostat is installed backwards.
    Gee, I wonder what that little plate laying on top of the master cylinder is for? :huh: :evilsmile
