Something came loose . . .
Discussion in 'Technical' started by mashori, Nov 8, 2011.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I was revving high and shifting hard, went from 1st to 2nd and then to 3rd, tried to go into 4th and missed it and went into 2nd by mistake. I was in the 6800 rpm range.
    After that the engine was making a knocking noise. But it was still driving ok. I towed it to the shop and this is what I found.
  2. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    wow did it snap the stud off or did the nut come loose?
  3. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    That will buff out.
  4. american opel
    american opel Member
    ashtabula
    1972 grabber 1967 opel kadett
    well atleast it looks like it just backed off.did it bend the pushrod?alot of guys watch me crank the hell out of my pollylocks at the track,this is why!!
  5. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    You'll have that sometimes lol
  6. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Had that happen to me when i did my rebuild, never went back to tighten everything down when i did 600 miles :/ luckily it was just a pushrod that bent
  7. Bryant
    so mo, who was with you when that happened?;)
  8. don graham
    Were you in the 6800 range when it happened? If so, what did the motor go to. That's why you need the rev limiter. Hope you had one.:oops:
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    well bryant, funny you should ask!
    So I was in the car with the girlfriend. Later the next day I said "dang car". She said "why are you blaming the car, you missed the shift and shifted wrong by mistake, isn't it your fault?" So I got called out on it majorly :)
  10. Bob Wiken
    Fayetteville, Arkansas
    ohhh, Mo, Snap,. she got ya
  11. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Sounds like she's a keeper!
  12. mojo
    "you missed the shift and shifted wrong by mistake, isn't it your fault?"
    YEP! I wud have to agree.
  13. CaptainComet
    Just wait until you're married ... they have a way of twisting everything into a final result where somehow it will always be your fault ... :rolleyes:
    A little duct tape, that rocker will be fine .... :p
  14. darren
    I couldnt have wrote that better myself. I cant describe how true that actually is. :rolleyes::)
    So long as she had nothing to do with that missed shift Mo.:16suspect
    Still be your fault anyhow.LOL.
  15. rthomas771
    I had something come loose before. I lucked up that the pushrod not falling in the lifter bore.
