Smog Equipment
Discussion in 'General Maverick/Comet' started by 66170MAV, Oct 5, 2010.
  1. 66170MAV
    66170MAV Member
    Lancaster Ca,
    Hello again.. I have a 70 Mav with an inline 200cid .. Iv been thinking about where to start. So I figured removing everything not needed on the engine would be prefect..Especially cause it will clean up the engine bay a bit.... Is there an egr on the 70, cause I dont see it?.. What else can be removed, and can I dump the cannister by the fire wall?.. I also have an electric fuel pump but the old one is still hangin on the block.. What block off plate will actually fit?... thanks
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    EGR valves came out around 1973.
    That is a charcoal canister down low, originally designed to vent fuel fumes.
  3. maverick75
    classicinlines.com has the block off plate. Be sure that the fuel pressure is correct. I wouldnt feel comfortable running an electric unit without a regulator, even if its for a carbed application.
  4. 66170MAV
    66170MAV Member
    Lancaster Ca,
    I thought about getting a pressure regulator too... With a 1bbl holley carb what should the pressure be at? Thanks for the help
  5. rthomas771
    4-6 psi on a 6 cyl...5-7 psi on a V8
  6. krelboyne
    krelboyne Remember
    Salem, Oregon
    An inertia switch would be a good idea too.
    Cuts the power to the electric fuel pump if you have an accident.
  7. 66170MAV
    66170MAV Member
    Lancaster Ca,
    Wow.. The fuel pump i have is rated from 2-4psi.. Its the autozone replacement pump for my engine, besides the mechanical fuel pump.. Is there anything else i can strip from the engine to gain power.. An electric fan may be the next upgrade... But I still want to know, is there even any smog equipment on a 70?..
  8. maverick75
    Can you post a picture of your engine? Some engines had smog stuff since the late 60s. But it also depends on where it was sold, i know CA and AZ engines had different stuff.
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Looking in my Motors Manual there is no mention of a smog pump system so I would say you have a PCV valve and the charcoal canister. Not going to pick up and power there.
  10. 66170MAV
    66170MAV Member
    Lancaster Ca,
    Well, thanks guys.. you've all been very helpful...
