SmallWaterLeak BetweenTchainCoverAndBlock?
Discussion in 'Technical' started by hotwheljoe, Mar 29, 2006.
  1. hotwheljoe
    hotwheljoe Member
    OrangeCounty
    1972 Mercury Comet
    we have a small water leak, look like where the timing chain cover meets the block. it was patched up (by the seller) when we bought it (a few weeks ago).
    he told us it needed a new cover. based on the attached pics, any advice or tips on what we should do.
    thanks a lot!
    joe
  2. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    You need a new gasket and replace the front seal while your at it, hell might want to install a new pump too, the cost of the parts are not that bad, can you do the work yourself?
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    I had one of these problems....turned out to be only the t-stat housing. Look closely at yours . Have your cooling system pressure tested...should show up. Let us know???
  4. don graham
    if it's the cover leaking, the only good way to fix it is to do it right and pull it apart, clean it up, new gaskets and reseal it. check to see if the cover needs to be replaced. they usully just need to be cleaned up. good luck.:)
  5. rayzorsharp
    The timing chain cover is made from aluminum and there is a water jacket going through the area you have the arrow. You're gonna have to pull the cover off which means water pump and all. I'm betting the water jacket inside the timing cover is going to be eat up and has probably gotten paper thin close to the block. The rusty water means no antifreeze in a while. If that's the case, might as well replace it. Anything else is just gonna be a temporary fix. Like the other guys said, might as well replace the water pump since you'll have it off too (preventive maintenance). You're also going to have the timing chain exposed...mighty cheap if it's got a lot of miles on it. I'd replace the heck out of it too.
    Here's what I figure you'll need:
    timing chain cover
    timing chain gasket set
    timing chain
    water pump
    thermostat & gasket
    permatex gasket sealant or equivalent
    anti-freeze
    six-pack of your choice
    3-4 hours to blow
    Good luck and have fun! :yup:
    Man, I sure do like spending other peoples money! :)
  6. sierra grabber
    sierra grabber Certifiable
    northern nevada
    BTW, orange county in what state?
  7. hotwheljoe
    hotwheljoe Member
    OrangeCounty
    1972 Mercury Comet
    thanks to everyone!!
    i live in orange county california (southern california)
    thanks for all your advise, i really appreciate it.
    i'm going to print out the advice you guys have given me and work on it with my buddy who happens to be a mechanic.
    joe
  8. Mavaholic
    Personelly, getting the timming cover back on with the oil pan in place is a royal pain in the ass. I would also drop the pan. Its pretty easy to do.
  9. Maverick Man
    California
    right!
    when i see that, the first thing i do is check the thermostat! and about 100% the time thats what it was!
    so i'd just double check to see if under the thermostat is wet ;)
    personally i have never had a timing chain cover leak b4.. maybe i ahve been lucky cuz my car leaks every where else! lol! :D but if it really is the timing chain cover thats cracked and is not the gasket.. i'd JB Weld it until you get the cash to repair it. That crap seals anything!
