Slow turn signals
Discussion in 'Technical' started by timers, Jun 10, 2011.
  1. timers
    timers Member
    richardson tx
    1974 maverick
    Why are my turn signals so slow with the head lights on?
  2. darren
    Charging voltage OK???
  3. timers
    timers Member
    richardson tx
    1974 maverick
    I think its charging ok what should i show at the alt, the batt never go's dead
  4. Moneymaker 1
    Panama City Florida
    Mine were real slow when I first got the car, so slow in fact I thought I had a battery going bad, I changed out the flasher under the dash and that fixed the problem.
  5. Acornridgeman
    Wisconsin
    Like Moneymaker1 said, I vote flasher. Replace the old mechanical flasher with a modern electronic unit - that should do it. Get a standard unit, don't buy the heavy duty one. That is for running the extra lights used with trailer towing.
    :thumbs2:
  6. simple man
    simple man Member
    Bunnell,Florida
    Check your idle speed. If it is too slow you can get this condition.:)
  7. baddad457
    The HD flashers work better all around than the std ones. With the std ones, these will not flash when you have a light burned out.
  8. Acornridgeman
    Wisconsin
    I agree when dealing with the old style thermal units.
    I suggested buying the modern electronic one and he will have no problems with the flasher. They run consistent with 1 to 6 lights in the circuit. Costs about $7.00
    :thumbs2:
  9. timers
    timers Member
    richardson tx
    1974 maverick
    Thanks to all just put a new flasher in. And didn't even start the car the thing has Hot Rod flashers now. LOL
  10. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    1976 ford maverick 302v8
    Aye, wnet electronic flasher for mine as well.... had the geriatric turn signals myself, so slow that someone said i had a brake light out :p
  11. timers
    timers Member
    richardson tx
    1974 maverick
    I couldn't belive it with just the key on and lights faster than before when running.
  12. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    Happens with age on those old mechanical ones, at least you have good quick blinkers now! I just swapped mine with the hazards for a while, as it was faster, then finally got off my ass and bought the 8.00 flasher
  13. 55crownvic
    55crownvic Member
    colorado springs
    anyone got a link to this "modern" flasher? I have sequentials and sooner or later the old flasher will bite the dust
  14. Moneymaker 1
    Panama City Florida
    Blinky Blinky Blinky.....glad ya got it worked out!!:bananaman
  15. timers
    timers Member
    richardson tx
    1974 maverick
    I just got this one, 552 upgrade, el12. By novita technologies.
