slight shifting problem...
Discussion in 'Technical' started by av'smav, Nov 9, 2004.
  1. av'smav
    av'smav Member
    Toledo Ohio
    74 maverick 302
    Hello to everybody!! Well it's been FOREVER but our mav is up and running...but it is having a slight problem shifting, we have a 74-302-automatic,and when you first startout it seems like it revs up too high before it kicks to the next gear.Is there a vacuum line that we might not have hooked up??:confused:
    Thank's Mike
  2. igo1090
    igo1090 Member
    catonsville, md
    there is a vacuum line running from intake vacuum to modulator valve at passenger rear of trans. lack of vacuum to it will usually cause high, often hard shifts. usually a metal line with a few inches of rubber at both ends. rubber might also have cracked and broken.
  3. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    i was having similar problems...turned out to be a sticky kickdown lever...not returning all the way. making up shifts sloppy and downshifts really sloppy not to mention annoying.
