simplest way to wire a Taurus fan?
Discussion in 'Technical' started by sam03rc, Jun 15, 2011.
  1. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    Can anyone brake down in the simple terms of wiring a Taurus fan with a manual switch? Thanks I'm a little electronic illiterate ahahhaha
  2. mercgt73
    For 1 or 2 speeds?
  3. Mavman72
    First... Determine which wire is the high spped feed wire on the fan. One is high speed, one is low speed and one is ground.
    Now...Quick and dirty...Ground from fan to ground on battery. Hot wire from battery to a 50 amp fuse then to toggle switch that will handle 50 amps...From toggle switch go to high speed fan lead on fan and you are hooked up. I would recommend running the fan through a relay since you will have fits trying to find a cheap toggle switch that will handel 50 amps...Good luck!!!
  4. sam03rc
    sam03rc Member
    gates county, nc
    You know that's a real good question haha I haven't gone to the junkyard to pick one up I was just going to get one for a 3.8 Taurus I guess just 1 speed since it will he simpler
  5. mercgt73
    What mavman said... (y)
  6. mercgt73
  7. bmcdaniel
    Ground wire to battery negative, one of the other wires to battery +
    Can't get more simple than that...
  8. Earl Branham
    Lugoff, SC
    Better put it on a relay unless you want to pop a fuse or circuit breaker when it comes on.
  9. sam03rc
    sam03rc Member
    gates county, nc
    Thanks guys ill get the fan and stuff thisweekend and let y'all know how it goes
  10. injectedmav
    injectedmav Member
    Georgia
    I highly recommend using at least a 50amp cycling circuit breaker in a Maxi'fuse holder instead of a fuse and at least 12ga wire, 10ga would be better.
  11. bmcdaniel
    For the high speed side you want 8 AWG.
  12. Jamie Miles
    Alto, GA
    I've had a few
    10 AWG been working fine on mine since 2008 and over 80,000 miles.. wires never get warm to the touch. Also using a 40 amp relay that has been working fine when supposedly that's not nearly enough..
  13. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Sam
    The best and SAFEST way is to use a Volvo Fan Controler . You can use the controler torun both low and high speed of the fan . Check tech articals for wiring diagrams..
  14. sam03rc
    sam03rc Member
    gates county, nc
    Ok I pickex up a fan today found out of a 96 cougar 4.6 fits great and is just a single speed then went to advance and auto zone and they didn't know what I was doing or how to do it I foulnd a 50 amp toggle switch. But I couldn't find a 50 amp fuse.? I found a blade style but not a holder is tgere a way to make one ? I'm confused honestly don't know what it looks like.I was figueing just running a 10 gauge wire from battery to fuse-toggle- fan and the a ground to the chase right?
  15. 71gold
    30 amp relay and fuse should be fine...any toggle switch will be fine to turn on a 30 amp (or even higher) relay...:Handshake
    the 2 speed-Taurus fan is the bad boy that needs the Volvo relay and heavier wiring...:thumbs2:
