shortie headers
Discussion in 'Technical' started by Unionmade, Sep 18, 2007.
  1. Unionmade
    Unionmade Member
    NONE
    Does anyone know if any companys make shortie headers for a 71 maverick with a 351W?? If NOT, What companies make a good full length? If you know the part#'s that would be helpful.
  2. Mavman72
    Long tube Hooker #6901 seems to be the header of choice around here.Do a search you will find tons of info regarding header choices on this forum.I dont think there is a shorty header that workes in a mav/comet.Good luck.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    There is a member on the forum that works for Thorley.
    He pressed the company into making shorties for us as a favor.
    That said, they are 302 headers, I doubt very seriously they would work on a W.
    I just brought it up because the previous poster said there were no shorties.
    He was talking about a 302 because the 6901s don't fit a W in a Maverick.
    You have several choices:
    1: Crites has a 1.75" header that goes in with little trouble.
    They get good reviews from the few that have them. They just came out earlier this year.
    2: Hooker has a 65-66 W swap header that can be used in a Mav, but it is a little more work to install than required for the Crites. They are about the same price as Crites, expensive. They also have 1.75" tubes.
    3: Tubular automotive has a 1.5" header for our cars.
    They require early SBF engine mounts and frame stands. The ones used up to mid-66. They are costly headers too.
    4: I believe it is Hedman that has the other swap header. It is slightly less expensive, but only has 1.5" tubes.
    5: There is a company that makes shorties for a 351w in a 65-66 Stang.
    They only come coated, and are very expensive as well. I believe they are 1.625" tubes IIRC. I don't know any Mav guys using this header, but do know of Stang guys using them and they fit great. I looked them over very good and they appear they will fit our cars too. I was considering them for a while. I haven't got my 393w started yet though, so I won't jump the gun and say I am going to try them.
    Probably just use the Crites now that they are out and seem to be the least amount of work to get big tubes on a W.
    6: I know you are looking for headers, but I have heard of members here using the stock 302 Mav manifolds on Ws.
  4. Sopp
    Sopp Member
    Eau Claire, WI
    1976 Comet 4 door, 1972 Comet 2 door
    Pardon the interuption..............................
    Has anyone used BBK-1512 Equal Length Headers? I'm planning on going with Mustang II type suspension on the Comet and will rid the car of it's shock towers. Should have plenty room.?.?. Rebuilding a 1987 F-150 roller 5.0 to go in it. A couple small 4-barrels and a mild cam to warm it up. Not sure about which heads to use, will do more research on that.
    Appreciate any real-world info on these headers.
    Thanks,
    Sopp
  5. newtoford
    newtoford Member
    New Castle Delaware
    if your going MII i would think the skys the limit for what you want to put under the hood.
